Thanks Davep, the case is strange in that the left half (zyl.1,2,3) has Dec.'64 markings and right half (4,5,6) seems to be Jan. '65. see pictures
Ps. I do have chain boxes a covers, only found 3 cyl. heads, but the dates are all consistent.
amatures practice until they get it right... Professionals practice until they cannot get it wrong. Dr. Porsche
'66 912 Irish Grun
'69 911T Iron Oxide
'70 914-6 Silber
'73 RS Blk/Rot (clone, of course)
'78 SC V1/R3 Gelb
'96 986 Silber Daily
Found : 1971 911T D series 2.2L engine SN# 6114843
Gytis
1967 911 matching numbers car ( sold )
1968 911T/R #0805 (SONDERWUNCH AUSSERH DER M.LISTE NR184****) SOLD
1969 911E MFI matching ALL numbers SOLD
1981 911 Target 4K ( SHIFT trip-Nürburgring-SPA and SOLD )
1986 930 "Carnivore" ( "while I'm there" mode )
I do not find that strange. The casting dates are quite scattered. I even have 901238 with an 11/64 case half. In fact, in that period my data does not show many matching case halves. It almost seems they made one half, then the other half; not both at the same time. I presume each half was machined separately on different machines; set up for just one half. Then the two halves were brought together and machined as a set. When the case set was finally assembled into an engine the casting sequence was well and truly lost. Certainly the sequence in which the completed engines were installed in chassis was quite jumbled. The car in which this engine was first installed was probably invoiced about the first week in April. So it was likely completed in mid to late March. That is about three months later than the case halves were cast. The transmission case for this car could have been cast in the 46th week of 1964. It appears that the supply chain for these parts could easily be 100 days long.
Found - 1971E engine# 6210238 located in Australia
On ebay case 4180064 (user = medwardco)
Aluminum 901/08 engine case from an early SWB Porsche 911S Sportomatic. Date stamped 1967. Engine serial # 4180064 I acquired this engine in a 1966 911 parts car
There is what I want, there is what I can find, and then there is what I can afford...
Following engine case are in Switzerland, for sale:
6136090
6230740
6391294
6332140
2180189
6301528
6670079
6101309
6101807
6210148
Registry member No.773
And also complete engine, in Switzerland, for sale
6193163
6372635
6143466
Found 901193
Still looking for transmisson for 71T
# 7115322
Finders fee available
73.5 Snrf T
71 Snrf T
70S targa
76 914 2.0
82 Targa,
85 Alfa GTV6
60 Lancia Appia Zagato GTE
