Results 1 to 2 of 2
Thread: Voltage Reg - 35 vs. 55 Amp?
    I'm replacing the volt reg in my 66 911 (35 AMP alternator) and notice that the replacement part I have, 901.603.206.02 (Bosch 0.192.062.007) is for 55 AMP alternators. Stoddards' manual states the 55 reg can be used on ealier cars with "minor modifications to regulator connections." Does anyone know what those mods are?
    John Schiavone
    Connecticut
    The 35 amp alternator uses three ring terminals and a spade lug for the connections.
    The 55 amp alternator uses two ring terminals and a plastic plug with 1/4" female fastons captive in it. These are perpendicular to each other, and the plug mates with the regulator connection on the alternator's brush plate.
  1. New Voltage Regulators - The Little Ones
    By Scott Clarke in forum Technical Info
    Last Post: 12-03-2010, 04:11 PM
  2. Voltage Reg. label
    By merbesfield in forum Technical Info
    Last Post: 04-17-2010, 02:41 PM
  3. Help with 73.5 Voltage regultor
    By mike walker in forum Technical Info
    Last Post: 07-24-2007, 02:01 PM
  4. Alternator or Voltage reg? 73.5T
    Last Post: 07-08-2007, 05:09 AM
