Results 1 to 10 of 11
Thread: Suggestions Wanted for 2.0 Mods
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    I'm going to put some $ and time into getting more umph from my 67 Normale. Starting with a running but long dormant orginal sand cast aluminum stock engine with 47K miles on it. Was thinking of switching to a 3.2 but decided to keep matching numbers. My goals are power, reliability, and low maintenance. Thumbed through Bruce Andersons book and have some ideas but wanted to bounce it off the board. Currently thinking of going to 2.5, crank fired dual plug, PMO's 44's, front oil cooler, better breathing and a E cam. Any ideas from anyone? Keeping the 901 and narrow body. Thanks,
    Bill
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Don't bore the case. You can go to 87.5mm bore (Nickies required), with a 66mm stroke you get a short stroke 2.4 on the stock spigot bore. With Mod-S cams and 36mm ports, 10.5:1 CR and twin plugs on carbs, this motor will absolutely scream.
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
    Thoughts
    I would change the heads to avoid the plug shrouding of the 2.0 litre design.
    I think I would use EFI instead of carbs as this will give a better power band and allow better driveability.
    I would certainy use short stroke to give power at higher rpm if you plan to stick with 901 transmission as high torque may damage the box.
    Bill,
    The below link currently represents everything I know about 2,0 liter engine modifications.
    http://forums.pelicanparts.com/tags.php?tag=901%2F05
    Starting with the bottom link, "suggestions for warmed over 901/05"-- you can see I began with the identical thought process. Eventually I came around to ONLY the following modifications:
    1) Bore to 81
    2) Custom JE 9,5 pistons
    3) Dougherty Supercup on 102 lobe center cams
    4) Oil bypass mod and piston squirters
    5) SC oil pump
    6) Updated 930 chain tensioners, idlers & sprockets.
    This should be good, with SSI exhaust, for a mild power and torque increase (I'm thinking around 150) and yet has the advantage of being completely original-appearing in all respects.
    The big problem with hop-up mods for an early 2,0 is the requirement of increased oil cooling. The factory went to external coolers with the 170HP 1969 911E, that should give you an idea of their view of the limitations of the original loop.
    Good luck!
    I agree with kenikh. Don't bore that case... 2.4 with good healthy compression would be really fun..
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
    Jun 2003
    Bend, Oregon
    A previous owner made some modifications to the original aluminum case engine in my '67 that I haven't seen anyone else do. The mods were done by a race engine builder by the name of John Bunin of Werkstatt of Vista, California. Modifications included:
    o New RS 2.7 pistons and cylinders
    o Two 2.7 engines were purchased to find a perfect crank and rods.
    o 930 cams
    o 40mm Webers built to 42mm - since replaced by 40mm PMOs
    o Billet aluminum pressure plate (EBS Stage 1)
    0 215mm clutch disc
    o Radiator style oil cooler
    The engine is fantastic: immediate response, no stumbles, virutally no oil consumption, torque everywhere, still pulling strong at 7100 redline - and bomber reliable. The PO told me that his goal was to build an engine that delivered over 200HP and that would be long lived. It's dyno'd at 220, so that part was accomplished. As to long lived, I'm still working on that. The car has been run hard at Portland International Raceway, Oregon Raceway Park, Infineon and various back-country roads and so far so good.
    Cheers,
    JohnA
    Restoration newbie.
    Jun 2007
    San Francisco
    Cross drill that crank if you're planning on revving it lots. Enlarge
    the centre main bearing oiling hole to ensure a good flow of oil into
    the cross drilled oiling hole and out onto the centre rod journals.
    Use the cam oil line flow restrictors to increase the supply to the
    bottom end.
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Nov 2008
    Finland
    Any particular reason why not bore the case? (pretty cheap and more hp for $)
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Jul 2004
    Sutalle, Ga.
    Thanks for all the suggestions. I'm overwhelmed with all the possibilities that a little 2.0 has to offer. Now the fun begins in deciding what to do, see how my budget will allow what I can do and then get it done. Special thanks to John for the exhaustive play by play on the "Bird". Shooting for being on the road by the end of the month. Will keep you all posted.
    Bill
    Currently:
    67S Concours King
    68 912 Flipper
    83 911SC
    93 Mo30 968
    R Gruppe # 551
    Dizzy
    Why not a Burns Bros distributor instead of crank fire - nice to keep the period-correct look.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
  1. Any Pelican Mods Here?
    By Dezzmo in forum Off Topic
    Last Post: 12-24-2013, 12:08 PM
  2. 912 mods for a hot rod
    By ckissick in forum Technical Info
    Last Post: 03-26-2012, 04:50 AM
  3. Smuggler's Box Mods
    By jameshtaylor in forum Technical Info
    Last Post: 06-14-2008, 06:31 PM
  4. RS Door panel mods
    By super9064 in forum General Info
    Last Post: 05-31-2008, 04:35 PM
  5. 2.2 E mods
    By 0687 in forum Technical Info
    Last Post: 02-09-2007, 12:23 PM
