Results 1 to 10 of 11
Thread: '901/23' Racing Crankcase
    Came across this today:
    http://www.carquip.com/parts/911/race/910/index.asp
    'Type 901/23 Factory racing crankcase
    with factory documentation.
    Serial # 5080006, stamped 10 856.
    Titanium head studs.
    Purchased from Vasek Polak Competition.'
    'Type 901/23 was a 2.0L racing engine of 80mm bore and 66mm stroke developing 210 horsepower with mechanical fuel injection.'
    $4000
    There's mention of some Ti-bits, but what other features/qualities makes this item special? Any motor Gurus here who can provide some more details about this?
    Rick Kreiskott
    Rick,
    Anderson lists this motor in his book but w/o much detail, link is here -http://books.google.com/books?id=QJVcgiQhRfQC&pg=PA108&lpg=PA108&dq=Porsch e+engine+type+901/23&source=bl&ots=lmLYoQ7BN8&sig=33kEWqPyPj0EG4uFJ6 kwxOToJrs&hl=en&ei=YtueSq_ODZOHmQfd-7y1Aw&sa=X&oi=book_result&ct=result&resnum=5#v=one page&q=&f=true
    I'll do some research tonight.
    Phil
    Early S Junkie # 658
    Jan 2003
    UK
    I think it was essentially the same as the 911R engine but with mechanical injection rather than 46 IDA Webers.
    I think the stated power output was actually 10 bhp more at 220 bhp.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    +1 Andy. 2 liter MFI racing engine, rare.
    J
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    901/23
    Quote Originally Posted by pu911rsr View Post
    Rick,
    Phil
    Hi, Phil . . .
    Thank you for the link. And I'd love to hear anything else you can find out. I've been looking at building a back-up motor and this came up. Pricey --- but Polak always kept The Good Stuff, so . . .
    Rick Kreiskott
    The 911r used a 901/22 case. What is the difference between a 22 and 23 case ?
    Oct 2008
    Burford, ON, Canada
    There was probably no difference between the cases with most of the 901/2x engines, The type # just differentiates between the the finished engine. Say between the carbed or fuel injected versions; although the changes there were probably more involved. There may have been both magnesium and aluminum versions of each engine though.
    Well, the 23 case has of course attachements for the MFI pump...
    mag race case
    the pictures are of top only. does the case have pressure relief and safety valve machining on bottom rear and side rear of case. gordon
    Oct 2008
    Burford, ON, Canada
    Apparently this case was sold several years ago, but the website cannot be corrected. A new website is being constructed. What is interesting about the crankcase is that it seems both types 22 and 23 shared the same serial # series 508xxxx. It would be very interesting then to check the 911R engines to see what serial #'s were used and what type each one was.
  1. WTB: 2.7 crankcase 7r
    By RealRS#406 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 11-26-2013, 10:49 AM
  2. WTB: 2.7 crankcase 7r
    By RealRS#406 in forum For Sale: 911 Parts
  3. FS - 914-6 Crankcase
    By tom1394racing in forum For Sale: 911 Parts
    Last Post: 02-15-2009, 05:39 PM
  4. FS - '69S Crankcase
    Last Post: 02-07-2009, 05:47 PM
  5. FS - '69T 1R Crankcase
    Last Post: 01-27-2009, 02:32 AM
