More cleaning.....
Aftermarket front sway bar 19mm probably either H&H or Pacemark....
100.00 + Shipping in the CONT US.
WIll need new bushings but I can add those with the bar if need be.
Tony
More cleaning.....
Tony
Tony Proasi
52 split window coupe
Tony - pm sent.
Patrick... Member #1707
'58 356
'67 911
'69 911
2nd in line ; pm sent.
JD
CRAP, CRAP, CRAP!
Put me third please! If you know of either a factory or another H&H front 18/19mm for sale y'all give me a ring!!!
Michael
-Dusty 70S Coupe
-S Registry #586
WOW !!!!!!
19mm H&H ....... That's a big part of my front set-up
Good parts, GREAT price Tony... would have bought'm just to have another...
Lucky buyer
Cheers
Thanks guy's...
The Bar has been SOLD
Tony Proasi
Chuck, Is that a Weltmeister kit, adjustable arms ??
I bought the same kit less bar at Hershey, found a H&H 20mm bar (actualy 20.5mm .812" dia.) and just bored the bushings to fit yesterday (pushed them out then glued them in and bored on a lathe)
Found the bar on that bird forum with a WTB ad.
Looking forward to trying it on the 71 targa with a 16mm rear bar for now, running a 19 F & 13 R on a 66 912, will try this out after the weekend.
Nope Jerry, mine's an H&H, identical to Tony’s......
Tell us how your new set up works.....
Cheers
Will Do, I was taking Tonys listing as H&H or____ to mean maybe he did not know the MFG of the kit, I do have the same kit and as in Tonys allen screws on the bar clamp (yours hex hd) same set up was just trying to confirm a manufacturer. Well made heavy welded pivot brackets.
I did ues the Weltmeister reolacement link bushings that were a good fit.
Thanks for the reply and will let you know how it sorts out, I think I need a bigger rear bar than the 16mm but it is a good start and the price was right, also a H&H kit I think.
