Thread: Push/Pull Clutch Cable Tension Question
    Drive 911's - Shoot 1911's gan911s's Avatar
    Jul 2007
    Adjusting push/pull clutch cable tension
    A few months ago I replaced my clutch cable when the plastic cable end failed.
    I set the tension, with the clutch pedal depressed, measuring 1" from the cable end to the back of the transmission case. At first I experienced smooth, positive gear selection, 1st to reverse and especially downshifting from 2nd to 1st. Now selection is sloppy. Going from 1st to 2nd is a fishing expedition trying to avoid what sounds like I'm clipping reverse.[B] I checked the distance from the cable end and back of the transmission case still 1"
    Appreciate your input.
    George
    Dec 2006
    Las Cruces, New Mexico
    From what you describe "fishing expedition", "selection is sloppy" it sounds like a shift coupler probem, bad bushings or combo. I have used the 911 transaxle on many applications and have ran into the same problem. If all the shifter mech was ok I just adjusted the cable until it did fully disengage not concerning myself about the 1".
    Early 911S member #166
    George, it does sound like the coupling under the plate at the back of the center tunnel.. Or the small coupling under the shift lever might have finally given up the ghost.. Good luck tracing it down. Bob
    Bob Petitt
    1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
    1971 911T Coupe 9111120264, my first 911 back in my garage
    1972 BMW 2002, my first car - 350,000 miles and counting
    1972 911T Coupe 9112100970, Sporto, parted it out..
    1983 BMW 320i, my everyday car - 138,000 miles and gutless
    2005 Subaru Outback, the daily driver - boring
    2006 Volvo XC90,
    Registry Membership #202
  1. FS 911 Decklid Pull Cable With T Handle
    By cog in forum For Sale: 911 Parts
    Last Post: 09-23-2012, 07:14 AM
  2. early push /pull switches NOS
    By Cliff in forum For Sale: 911 Parts
    Last Post: 03-01-2012, 08:44 PM
  3. push pull switch s
    Last Post: 01-13-2012, 07:42 AM
  4. 71 pull clutch question,I have searched.still stumped
    By chiroracer in forum Technical Info
    Last Post: 04-24-2011, 12:32 AM
  5. FS 70-71 new Clutch Cable
    By Carrerax in forum For Sale: 911 Parts
    Last Post: 08-02-2010, 10:11 AM
