Results 1 to 10 of 11
Thread: Early Camber Plate Rubber Bushes
    I will have new camber plate rubber bushes available in about 10 days.
    The bushes are manufactured from Natural Rubber and are uprated from the standard bush.
    They will fit all early cars up to 1969 that use the two seperate bushes and a steel spacer tube.
    We will supply them with zinc palted and passivated steel tubes, dished washers and hexagon nuts.
    I have enough for around 25 cars.
    Dec 2006
    Las Cruces, New Mexico
    Depending on price Chris I'm in for a set.
    Early 911S member #166
    Control Arm Bushes
    I had expected the Camber Plate bushes to arrive first but the Control Arm Bushes beat them by a few days.
    These bushes are made from Natural Rubber and have been matched correctly to the original material.
    We have matched the Shore Hardness, the static stiffness, the dynamic stiffness and the hysteresis.
    The bushes fit to the control arms with the same level of radial compression as the standard part to ensure that they perform correctly.
    They will be quite tricky to install but we can supply a sketch of suitable tooling.
    We will also be making Spring Plate bushes in Natural Rubber but with an uprated level hardness.
    I expect spring plate bushes in about 3-4 weeks.
    Dec 2006
    $ per set? Mark S
    Bushes
    $75 + Postage from UK at $10
    Early Camber Plate Bushes
    The washers, which have been the hold up, finally arrived and the full kits are now in stock.
    Just to be clear about pricing:
    Camber Plate bush kits complete with steel sleeves, washers and nuts
    $100 per set + $10 postage.
    A - Arm Bushes $75 per set + $10 postage.
    Uprated Natural Rubber Rear Spring Plate Bushes will be ready in 3-4 weeks.
    Feb 2003
    Corpus Christi, Texas
    This looks like the hardware and bushings Koni supplies with their inserts.
    Jason Burkett
    Paragon Products
    www.paragon-products.com
    Early 911S Registry #428
    R Gruppe #375
    1973 911S
    1972 911T
    1974 914 Limited Ed. Blk/Yellow
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
    1968 Shelby GT500 Conv.
    2010 VW GTI, Daily Driver
    Feb 2003
    Los Angeles
    Yes, I received the same bushings and washers with my new Koni Red strut inserts.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Hey I have those parts laying in my Koni xtra parts bin.
    Feb 2003
    We have a bunch as well. 15 years of selling the stuff makes for a pretty large spare parts box.
    Jason Burkett
    Paragon Products
    R Gruppe #375
    1973 911S
    1972 911T
    1989 944 Turbo
    1993 968 Turbo RS
    1967 Shelby GT500
  1. Camber plate stuck to insert...Help Pls
    By timgt3 in forum Technical Info
    Last Post: 01-01-2014, 10:56 PM
  2. Camber Plate Bush
    Last Post: 11-30-2013, 10:17 PM
  3. Early Camber Plates and Bushes
    Last Post: 03-02-2011, 08:43 AM
  4. WTB: Rubber Grommets for MFI Fuel Filter Mounting Plate
    By RTincher in forum For Sale: 911 Parts
    Last Post: 10-01-2006, 09:03 AM
  5. camber plate front strut
    By thback in forum Technical Info
    Last Post: 09-18-2002, 02:23 PM
