Book says changing dwell changes timing but does'nt say which way. How does changing dwell change timing? If I increase dwell, does advance increase or decrease?
Thanks in advance, (no pun intended)
Rob
__________________
Rob
__________________
356Robo
64 C Coupe #218448(sold)
70T Targa #9110110416(sold)
increase dwell = decrease point gap = decrease advance in timing..
Bob Petitt
1967 911S Coupe 307653S, my barn find - 55,000 miles Looking for engine #961269 and trans 901/02 #104337
1971 911T Coupe 9111120264, my first 911 back in my garage
1972 BMW 2002, my first car - 350,000 miles and counting
1972 911T Coupe 9112100970, Sporto, parted it out..
1983 BMW 320i, my everyday car - 138,000 miles and gutless
2005 Subaru Outback, the daily driver - boring
2006 Volvo XC90,
Registry Membership #202
Thanks Bob,
I'll regap the points a little closer and hopefully get the advance down a little. Right now, its at 4' Atc and about 34' btc at 6,000.
Rob
356Robo
In a basic ignition system (non-electroinc) dwell is the amount of time the points are closed. While the points are closed the coil is storing energy in the form of its magnetic field. If dwell is too short you might not get the correct amount of energy stored up in the coil which results in a weak spark.
The spark occurs when the points open (and the stored energy in the magnetic field collapses)
In basic ignition systems you should set the dwell per spec before you set the timing. Get the dwell set so that it maximizes the energy stored up before the points open and the spark occurs.
A normal timing light will trigger of the leading edge of that spark. I won't go into what is going on during the spark.
So if you set the dwell, then the timing you should maximize the energy in the spark and have the spark occur at the correct time.
In some basic ignition system this is an iterative process so always check the dwell after setting the timing, correct it if needed and repeat.
Tony
68 Sporto Project
2016 Boxster
Rob,
If you can recruit someone to crank the car (with cap off) and you stay back to adjust. You can get good dwell numbers with cranking rpm. You won't have to walk back and forth or remove/reinstall the cap.
Olin - Member #1375
1972 911T
Original
Options added
There's a one-to-one relationship between dwell angle and ignition timing.
Sherwood
So you are saying that 1 degree of increased dwell equals 1 degree of decreased timing (or the inverse)?
Never too old to learn. You would think after 42 years of setting points I would have known this was a 1:1. Thanks.
