Thread: where would I find ?
    where would I find ? - NOW FOUND
    the two bolts / plastic caps that fit in engine lid at top of grille......the two holes in lid are for mounting a wiper I believe and I removed mine and have the two holes - should there be a chrome bolt or a plastic plug in the two holes and where would I look
    hope this makes sense......for a 70 car
    thanks in advance
    paul
    70 911 aquamarine
    fahr'n fahr'n fahr'n auf der Autobahn
    [SIGPIC][/SIGPIC]
    mike
    i have an engine lid grille - there are two bolts at top that cover / fill the holes in lid when no wiper motor is fitted
    paul
    70 911 aquamarine
    [SIGPIC][/SIGPIC]
    well I found a temporary fix - I removed the rear wiper and replaced two holes with cycle brake domed nuts , the ones for brake calipers - fitted with small rubber grommet (all from cycle store) and it looks fine - the nuts could easily be sprayed satin black
    mine look nearly identical to the one that is part of rear wiper assembly
    photo taken with iPhone so not hi res
    paul
    70 911 aquamarine
    [SIGPIC][/SIGPIC]
  1. Need help with a barn find
    By eclipse in forum General Info
    Last Post: 10-27-2013, 07:41 PM
  2. How do I find out...
    By Nordschleife in forum General Info
    Last Post: 04-25-2013, 06:21 PM
  3. Help me find a car
    By AirKuhl in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 09-17-2010, 11:05 AM
  4. Box Find!! / Barn Find
    By jonnyw in forum General Info
    Last Post: 06-29-2009, 07:23 PM
  5. Where do I find new 38 cm Prototipo
    By parced@telia.co in forum General Info
    Last Post: 04-20-2009, 04:58 AM
