Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: replacement sheet metal for SWB beneath battery?
    Dec 2004
    SE Michigan
    Wondering if there is replacement sheet metal available for the exterior panel located beneath the battery. I am not talking about the pan. The portion I need is part of the wheel well panel, but I only need the very bottom. I do not want to buy a whole wheel well panel. Hoping there's something out there that would save me fabrication time at a reasonable cost. For example, I seem to recall the lower portions of fenders being available. Maybe the same is true for this piece?
    EDIT-->BTW, this is the part I'm talking about bottom of circled area
    Bill G.
    EarlyS #718 | RGruppe #437
    Nov 2008
    Finland
    Unfortunately as you can see from my post back then, there is no panel available. Only chance is to cut it from car that its in decent condition, they are often rusty though.
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Bill, long time no see, is that blue/yellow/oxide car together and on to the next? I can fabricate you a replacement section of the outer lower wheelhouse- starting at pan pinchweld up to/just past the wiring/fender support tube -front of bulkhead to as far back. its a bunch of forming welding shaping, when done is a nice repair as to nothing else around. I use an oem part for my model/fitment check.
    Dec 2004
    SE Michigan
    Damon,
    Good to "hear" from you. Sent you an email through ESR.
    -Bill
    Bill G.
    as requested SWB lwr whlhse sections by SERIES900
    $10.00 of sheetmetal+ 6hrs+30 years experience per panel
    those are beautiful!
    bob moglia
    '72 E sunroof coupe
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Holey sh*t you don't want to make me one for a 69 do ya?
    Very nice work
    Dec 2004
    SE Michigan
    No arguing about it...Damon is the man. That is art!
    Bill G.
    Thumbs up
    nice....pm sent
    Richard aka le Zookeeper
    early reg #1128
    69-73 left side lwr wheelhouse
    Per classic request, yes I can !
  1. replacement sheet metal for SWB beneath battery?
    By Toffynose in forum Technical Info
    Last Post: 11-12-2013, 02:47 PM
  2. wtb sheet metal for a 71
    By Sean F in forum For Sale: 911 Parts
    Last Post: 11-09-2009, 02:20 PM
  3. sheet metal ???
    By mkampaflis in forum Technical Info
    Last Post: 06-22-2009, 01:09 PM
  4. Replacement floor sheet metal
    By Will 1967 in forum Technical Info
    Last Post: 02-22-2009, 10:54 AM
  5. FS : SWB Sheet Metal
    By jonnyw in forum For Sale: 911 Parts
    Last Post: 09-17-2008, 09:27 AM
