Thread: Warning on Using Brake and Carb Cleaners
    I found this on the Shelby forums.
    I don't know how many of you Gents (and Ladies) use Carb Cleaner and Brake Cleaner that's available in aerosol spray cans from various companies. But be VERY careful when it’s exposed to high heat.
    This guy was using some to clean up areas he was about to weld, just like he had a hundred time before. This time, however, the cleaners didn’t completely evaporate, the high heat and acetylene gas reacted with it and created a toxic gas (hydrogen chloride) that almost killed him. He still will have some long term effects.
    Who knew we were supposed to actually READ the warning labels!!
    http://www.brewracingframes.com/id75.htm
    [SIGPIC][/SIGPIC]
    1972 911S Targa Paint to Sample Cocoa/Tan Leather (# 0836)
    Other Early:
    1974 Carrera SR Coupe (USA) GP White/Tan Shetland Cloth/Gold "Carrera" Stripes
    1971 911T Coupe Tangerine/Black (Destroyed in fire at Porsche Shop )
    1968 912 Coupe Irish Green/Black
    When In the "Dark" Side:
    1988 944 Turbo S Alpine White/Gray (1 of 481 Turbo S's Imported into USA)
    1991 928GT Guards Red/Spec Order Gray (1 of 85 GT's Imported into USA for 1991)
    Current Daily Driver: 2007 Shelby GT Mustang
    Jul 2008
    South Florida
    What's scary is how frequently these products are used in proximity to high heat, given their purpose. Labels do warn about phosgene... no matter how these solvents are used, good ventilation is required. A big shop fan has been my answer but I'll never use brake-clean around heat ever again. That anectdote is frightening as hell. Poor guy's affected forever.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Michael - 69E Michael - 69E's Avatar
    Dec 2008
    Top of Denmark
    VERY scary stuff.
    Same components are found in freons in aircon units - so be careful with those as well.
    Michael Christensen
    911 E, 1969, Tangerine, matching #s
    911 Carrera 3,0, 1977 Indisch Rot​, matching #s
    Alfa Romeo Giulia Sprint GT Veloce, 1967, Alfa Rosso 501, matching #s
    Ariel Red Hunter, 1952, Maroon
    Oct 2008
    Burford, ON, Canada
    Hydrogen chloride when dissolved in water becomes hydrochloric acid. Weaker forms are known as muriatic acid used for etching metal and concrete. Weaker still, it is the acid in your stomach that digests the food you eat. Defintely not something you want in your lungs.
    Dec 2004
    SE Michigan
    Thanks for the warning. Reminders are always helpful, especially when you don't weld frequently it's easier to forget...
    Bill G.
    EarlyS #718 | RGruppe #437
  1. Warning contact on brake master cylinder?
    Last Post: 09-04-2012, 04:46 PM
  2. Blinking brake warning light
    By rpc356 in forum Technical Info
    Last Post: 06-16-2012, 04:02 AM
  3. Replies: 2
    Last Post: 07-18-2008, 06:11 AM
  4. Brake Master Cylinder Warning Switch
    By HarryD in forum Technical Info
    Last Post: 01-05-2007, 02:08 PM
  5. Brake Plating Detail. Warning: Fussy Details Inside.
    By bobmagyar in forum Technical Info
    Last Post: 03-26-2005, 09:33 AM
