Results 1 to 9 of 9
Thread: Need safe gentle cleaner for 68 anodized aluminum window trim
    Senior Member hgarazo's Avatar
    Jan 2004
    Frederick, MD
    Can anyone suggest just a safe, basic cleaner for the window tirm on my '68. It's in pretty good shape, but has some water spots, etc. I tried some searches, but all involved restoration.
    Chrome cleaner? I was concerned that chrome polish would strip off the anodizing.
    Henry Garazo
    '68 Polo Red 911L Barn Find
    '70T 2.7 Coupe
    '58 1600S T2-A Speedster
    '87 Triple Black Carrera Coupe
    "Form Follows Function"
    Early 911S Registry #962
    Potomac Region PCA
    Goldmember ttweed's Avatar
    La Jolla, CA
    Henry-
    For mild cleaning like that I have always used Mothers® Mag & Aluminum polish. It may take several applications and a lot of elbow grease, but is definitely not so abrasive as to attack the anodizing.
    A chrome polish like Simichrome does not effect the anodizing either, in my experience.
    TT
    Tom Tweed
    Early S Registry #257
    R Gruppe #232
    PCA National DE Instructor
    Read my surf novel!
    Jan 2004
    Frederick, MD
    Thanks Tom! I'll try the Mother's since it's easier to find.
    Henry Garazo
    '70T 2.7 Coupe
    Potomac Region PCA
    Cleaners
    Surely Mother's Aluminium cleaner is an abrasive that is designed to remove an oxidised surface from aluminium.
    I used to use it to clean my unpainted Lotus Se7en and it was excellent.
    It will, however, eventually polish through the oxide film that is produced by anodising and spoil the finish.
    If the anodising has stained due to some chemical fall out it is unlikely you will be able to remove any discolouration with a polish. You would probably have to polish and re-anodise.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Please correct me if i'm wrong, but 68 where chrome. The change to aluminium window frame was MY69.
    Stick a magnet on it, to make sure.
    Maguires all metal polish does a really nice job.
    Tony
    Dec 2004
    SE Michigan
    Ok, you're wrong.
    '68 are one year only anodized aluminum vent windows.
    earlier versions are chromed brass, I believe.
    '69 went to fixed windows, IIRC.
    Bill G.
    EarlyS #718 | RGruppe #437
    Hi Henry,
    I found a product sold at Home Depot called Spot-X Hard Water Stain & Spot Remover. It worked great on glass and trim. http://www.glass-restorer.com/
    Best regards,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Jun 2003
    Toronto
    Try rubbing some Vaseline on the spots.
    Nov 2004
    Gold Coast.
    Thanks Bill,
    Always keen to learn.
    Tony
  1. FS-NOS aluminum 1/4 window lower trim
    Last Post: 10-03-2012, 10:52 PM
  2. Stoddard Aluminum Window Trim
    By YTNUKLR in forum General Info
    Last Post: 01-04-2011, 11:24 PM
  3. Wheel arch trim/anodized fender trim S pkg
    By mrbeverlyhills in forum For Sale: 911 Parts
    Last Post: 03-18-2008, 07:55 PM
  4. Anodized door and window trim for a 73
    By ret9191 in forum For Sale: 911 Parts
    Last Post: 06-22-2007, 11:06 PM
  5. restoring anodized aluminum trim
    By caproader in forum Technical Info
    Last Post: 08-19-2005, 12:03 PM
