Thread: 911S Heads Paired with 911E Cam Shafts
    Dec 2007
    East Coast, USA - Tysons, VA
    I wanted to ask your kind advice, please, because I want to be sure I do not make any mistakes in rebuilding my 2.4 engine. Your expert advice would be highly appreciated.
    What do you think of the combination of 2.4 911S pistons and cylinders, whose lower compression ratio will allow the use normal pump gas, freshly made E profile cam shafts, and 911S spec (36mm intake ports), with 2.2 911S stacks and throttle bodies? Would the use of E cams on an otherwise S-spec engine allow for more useable torque than I would get with S-cams? Thanks.
    I would think the large ports would compromise the torque you are trying to gain with the e camshafts. 2.4Ss have plenty of torque, why not just use S cams? Especially considering you have some fairly valuable S pieces accumulated.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Dec 2007
    I may just have to do that! Thanks.
    Sep 2006
    Maryland
    I agree, use S cams, lack of low end torque was a issue with the lower displacement S's mostly the 2.0, by the time the motor had grown to 2.4, slogging around town in traffic was much easier.
    Rob Abbott
    I tried to cure a midrange lean condition in a T by using an E pump. Didn't work very well. would recomend sticking with cook book recipe. S heads, S cams, S injection. Compression not as important. Gordon
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    My short stroke 2.5 has E cams with S ports and S MFI throttle bodies and stacks. It seems to work quite well. It bounces off the rev limiter (7100 rpm at the moment- I am going to switch out the rotor for a 7300 rpm unit) in first second, and third. It pulls cleanly from 2500 rpm. Power does taper off above 6500 rpm, but it is still pulling nicely. MFI pump is an E unit with the silver internal screws turned all of the way in, and a shim under the barometric cell. My understanding is that the ports on these motors are on the small side. I decided that the 2.5 configuration waranted the larger ports. Plus, I can now change the cams without pulling the heads, something I am contemplating.
    John Luetjen, active on the Pelican board, has put a lot of thougth into this issue and has done a lot of research. I'd do some searches over there, and contact him if you still can't decide.
    I will say that it is nice having a motor that allows me to be occasionally in the wrong gear without much penalty.
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
  1. Chambers of Cylinder heads 911S and 911E (1967-1969)
    By Elferhelfer in forum General Info
    Last Post: 02-19-2014, 09:57 AM
  2. FS: 1970-73 911S cylinder heads, matched set of genuine S heads
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 03-07-2013, 05:15 AM
  3. Replies: 4
    Last Post: 12-24-2010, 03:12 PM
  4. FS- Very Nice Used 1969 911E Heads
    By 72tii in forum For Sale: 911 Parts
    Last Post: 10-29-2009, 02:00 PM
  5. FS - 2.2 911E MFI heads
    By Steve G in forum For Sale: 911 Parts
    Last Post: 04-05-2007, 08:15 AM
