Results 1 to 8 of 8
Thread: Gibbs lube - anyone used it ?
    Sep 2008
    Auckland , New Zealand
    Talking Gibbs lube - anyone used it ?
    i have been reading up on the properties of Gibbs lubricant for the conversion of rust and protecting metal on car bodies prior to painting .
    I find it questionable , as a lube , that you can actually paint over it with out issue ?? can some one vouch for the product?
    Link http://www.gibbsbrand.net/
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    May 2006
    CT
    I used Gibbs regularly for protecting all metal parts from corrosion. it does a great job.
    I have a couple of steel head studs that I bead blasted, coated with Gibbs and let sit on top of my workbench for close to a year. No corrosion.
    I have never tried to paint over it although I could give it a quick try on these head studs and let you know what I find.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Works great on magnesium. Works even better ion a Glock.
    Oct 2003
    Rhode Island
    It really does work very well at stopping rust and corrosion on bare metal.
    I have painted over areas that were sprayed. Obviously you have to let the Gibbs dry before painting over it, but the paint does stick.
    '74 leichtbau
    "Sascha"
    R Grp 246
    S Reg 823
    I have the same experience as those above. Works fantastic on all magnesium(and other metals) parts, prevents corrosion/discoloration.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Oct 2008
    Burford, ON, Canada
    Do you have to order from the website, or can it be purchased at retailer locations (and if so, who carries it)?
    Feb 2005
    Lake Tapps, WA
    Yep, works fantastic. Just order a case and split it with a local buddy. You'll use it for everything. I use it on fuchs, fans, engine cases etc. I also use it on guns, stainless sinks and many more.
    '67 911S
    '69 911S
    '70 911ST
    '73 911T Targa Signal Yellow
    '11 Spyder
    Early S#1097, R-gruppe #
    May 2006
    CT
    I call the number listed on their website and order it by the case.
    Tom Butler
    1973 RSR Clone
    1970 911E
  1. Gibbs Brand Oil - Need Favour
    By Fishcop in forum Australia
    Last Post: 04-03-2012, 09:57 PM
  2. Gearbox lube:
    By JackG in forum Technical Info
    Last Post: 05-21-2009, 08:08 AM
  3. Gibbs Brand available in Europe !
    Last Post: 04-01-2008, 06:56 AM
  4. Need a favor, Gibbs Brand
    Last Post: 02-28-2008, 12:23 PM
  5. fan/housing oxidation: is gibbs the answer?
    By Kaleid in forum Technical Info
    Last Post: 10-26-2007, 02:50 PM
