For sale: 1969 S sunroof Porsche 911 vin # 119300280. Original Irish Green color. Porsche COA included. Meticulously maintained by Callas Rennsport in Southern California, the car needs nothing and drives and handles beautifully. Perhaps just as important, the car has absolutely no rust and is an original California car. Asking $65,000. Please email me at mharmon944@gmail.com if you would like any additional information or pictures.
Here are some specifics:
Engine/transmission
SSI stainless heat exchangers
Dansk Sport muffler (factory muffler included with the car)
Rennline Shifter
New shifter bushings
Wevo shift coupler
New clutch cable & bowden tube
New fuel pump
New factory engine sound pad
New engine mounts
Rebuilt 901 transmission w/ the following gears (915 trans available):
A 11:34
F 18:34
M 22:29
V 27:25
ZD 31:22
All new synchros, gaskets, seals, flywheel (balanced), clutch disk, pressure plate, pilot bearing
2.9 liter motor built by Paul Wier on 2/10/00 (all paperwork included) - less than 12,000 miles on this motor.
7R case
Standard crankshaft
930 chain tensioners
New Andial 2.9L pistons and cylinders
New 911 S cams
New PMO 40/36 intake manifolds
New head studs
New Raceware rod bolts
New case timeserts installed
New valve guides installed with valve job
Pertontix ignition
Weber 40IDA carbs
Compression:
#1 152
#2 155
#3 150
#4 150
#5 155
#6 155
Leakdown: 3% across all cylinders
Suspension/Brakes
Sway Bars: 18mm front, 22mm rear (with new bushings)
New Bridgestone RE960AS tires: 195/60R15 front; 205/60R15 rear
Recent 4 wheel alignment
15mm adapters by Ralph Boothe on all 4 wheels
New master cylinder
New brake pads/rotors
New shocks – front and rear
New rear spring plate bushings
New front and rear wheel bearings
New brake master cylinder
Body/Paint
Front suspension pan professionally replaced
Front tie downs
Original 7R wheels in rear restored by Harvey Weideman
Original Deep 6 wheels w/ hearts in front restored by Harvey Weideman
Hand painted center caps
Headlight/foglight rewired with 12 guage wires and relays (in smugglers box) to accommodate 100W H-1 bulbs
Original Bosch Yellow H-1 headlights with 100W bulbs (with upgraded wiring and relays)
Original factory chrome crash bar in perfect condition
Interior
Period correct Blaupunk Frankfurt digitized by Electro-Tech, with concealed ipod jack
Luggage valet by Appbiz (original rear seats included)
Kill switch
Double wrapped steering wheel with original batwing
Bucket seats
Halon fire extinguisher with Brey Krause quick release mount
10K tach by North Hollywood speedometer (original tach included)
Factory deadpedal
Correct, factory door pockets
Back and white Coco Mats
European driver’s side arm rest (original included)
POR-15 on entire interior
Dynamat Extreme on entire interior
New lightweight carpet by Appbiz
Perfect Dashboard
Misc.
New Porsche batteries
New sunroof cables and deflectors
New 24 gal (1974+) Porsche gas tank professionally coated and painted
Strut Brace
Clock converted to quartz by North Hollywood Speedometer
Pedal assembly professionally rebuilt, powder coated and rebushed 6/2/09
Carriage undercoated
New heater cable tubes
New heater cables
New heater hoses
New front hood shocks
Various spare parts included
Thanks for looking.
