I would like to buy 1 or 2 MFI injector(s) in known, good working order. Let me know what you have and how much you are asking.
Regards,
Al
Regards,
Al
Al Kosmal
the X-faktory
Current projects; 69-911.5
76S rat bastard---off to Germany
1970 914-4...off to Wisconsin
73 911X Cafe Racer...........(off to S.F.....now racing in Germany)
66 912 ...off to France
71E 9111200979 ( gone to Paris..then to Corsica)
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
I have some that have been sent out and cleaned and tested. New they cost $150. These are $75.each. If interested,email >eurotech@together.net<
Rick; sorry to hijack, but where have you sent mfi inj for testing. I have a few spares that I would like to have tested.
Early 911S Registry #931
1971 911 2.2T Coupe Tangerine
It's done here is the states. There has to be someone near you that does it. Maybe a big truck diesel shop?
John,
I bought one of these Diesel injector testers from Mercedes Source in Bellingham, WA. They are a 1/2 hour from my house, but have an Ebay store. Link is below. These are designed for Mercedes (Bosch) Diesel injectors, but the fittings happen to be compatible with the MFI injectors. I've modded mine with a 0-300 psi gauge. Works very well. No interest in this company, just a happy customer.
http://cgi.ebay.com/ebaymotors/Diese...item588385afa5
Regards,
al
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
Thqanks for the link Al!
PS I have checked with a few Bosch diesel shops in Norway, none of them have equipment for testing the old injectors.
I have a nice OTC injector tester myself. The tool you posted a picture of, and mine, don't really clean injectors. They just check for leaky one, and you can check the spray pattern. The injectors I offered to the original poster were ultrasonically clean and tested a couple times.
Hi Rick,
I am both the original poster and the poster of the injector tester link. I also suggest that you have your injectors ultrasonically cleaned. You can soak the injectors in cleaner and then pump cleaner through the injectors, using the tester. This works ok ...but it's not as effective as the ultrasonic cleaning. However...small ultrasonic cleaners are readily available and somewhat inexpensive.
regards,
Al
Al Kosmal
the X-faktory
77S (off to NY)
Early S #1240
RGruppe #669
www.x-faktory.com
rick,
i got a bunch of injectors cheap.
they look good but....
do you know of a place i can send them to be cleaned and tested?
and what can i expect to pay?
or should i buy that gizmo from mercedes?
anyone?
bob moglia
'72 E sunroof coupe
