Thread: Q: whats de difference hella 139 and 169?
    what year is correct for each? and how to tell difference between driving light and fog light?
    Richard aka le Zookeeper
    early reg #1128
    I have seen differences in the mounting, but I do not know if it is specific to the 139 or 169. For instance, there is a rear mount post on my 169's (marked 169 on lens, but 139 on inside label) and I have seen identical type lights that has one at mounts on the top. Ironically, the Hella box my came in (139) had a picture of the top mount. See below There are many discrepancies, and I think that ultimately, you need the ones with the rear post to fit lights after the 128s.
    As far as the fog/driving lights, this is dependent on the lens. I have only seen fog lenses for this style.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Dec 2013
    Connecticut/Florida
    I have a 1972 911T that does not have the S front spoiler. I'm still confused by the correct model under the bumper Hella fog light. Is it the Hella 169? Or the 139?
    1971 911S Coupe - Gemini Blue
  1. Replies: 28
    Last Post: 09-03-2013, 11:41 AM
  2. whats gas to use?
    By ds58 in forum Technical Info
    Last Post: 11-21-2012, 10:02 AM
  3. difference in euro and ROW hella 128
    By freezing14 in forum General Info
    Last Post: 07-22-2010, 03:59 PM
  4. Decklids, whats the difference?
    By teveo in forum Technical Info
    Last Post: 11-19-2008, 11:35 AM
  5. whats the difference between 40IDA3C(with S stamped on)/IDS3C's
    By turfclubroad in forum Technical Info
    Last Post: 02-28-2005, 10:46 AM
