Results 1 to 7 of 7
Thread: gas door paint
    gas door paint
    hey you original paint guys.
    is this paint scheme correct for a 72?
    or should the hinge plate and latch mechanism be unpainted?
    and is the black background correct?
    (this is from darryls 912)
    a picture from an original 72 would be great!
    thanks
    bob
    bob moglia
    '72 E sunroof coupe
    Sep 2006
    La Quinta
    Bob,
    I have never seen the inside painted black before.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    thanks john,
    do you recall if the hardware is painted or not?
    bob moglia
    '72 E sunroof coupe
    gas door paint
    Rob, everything was painted assembled, the filler neck wasn't installed nor was the rubber cuff. The gas door was installed, so the exposed ends of the bolts were painted. The latch mechanism spring and cotter key was installed and painted. You want to put the rubber buffer in, and adjust the height of the latch arm for gas door fit, before the fender is installed. Getting access to the adjustment bolt after the fender is on will make you not want to do that again. Remove the rubber buffer before painting. The fender was installed before painting which is why you'll see paint on the fender attachment bolt heads except the ones retaining the trunk carpet snaps. The bolts at the cowl were left loose so the beading could be installed after painting.
    thank you ed
    BTW what happened to your front pan replacement site?
    its gone and missed!
    i tried sharing it with others but no go.
    it was my main reference for my repair.
    bob moglia
    '72 E sunroof coupe
    Here is the fuel fill in my 73, which has original paint.
    Tom F.
    Long Beach, CA
    gas door paint
    It went away when we changed servers, PM me your e-mail and I can do a link.
  1. Replies: 6
    Last Post: 07-04-2013, 11:53 AM
  2. 1966 911 inside door paint
    By bobm in forum Technical Info
    Last Post: 02-11-2013, 02:33 PM
  3. Engine Fiberglass Cover-to paint or not to paint?
    By Varooom in forum Technical Info
    Last Post: 03-28-2010, 05:44 PM
  4. How to stamp paint code #'s in door jamb plate
    By caproader in forum General Info
    Last Post: 03-15-2009, 06:19 PM
  5. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
