Thread: 72 911E fuel pump wires
    Hi
    Iam doing some work on my 72 E, and PO had the E stuff taken away and put on some zenith carbs.
    Could some one post some fotos whre the wiring coes trugh to fuelpump?
    iam going to install back all to E speck.
    Thanks in advance.
    i work with sculptures on wheelshttp://picasaweb.google.com/Jancarfactory
    Jan, call me. I converted my 71S from carbs to MFI.
    John L.
    Early 911S Registry #931
    1971 911 2.2T Coupe Tangerine
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    MFI fuel pump wiring
    Jan, I can post a wiring diagram (a short version) if needed.
    911e
    hi that would be great!
    my email adress is jan@jancarfactory.com if u need that as well
    Jan, I know you're getting the wiring schematics, but to answer your question, there is a two pole white plastic plug near the fuel filter and it lays on top of the shock absorber crossmember. The fuel pump harness section has the mating two pole plug which then goes through the gap to the front of the shock crossmember and basically follows the path of the fuel lines down to the pump. I think the power wire to the plug by the filter is red w/green tracer, however the wire from there to the pump is blue, the other wire in both cases is a brown ground wire. Clear as mud eh!
  1. FS: MFI Fuel Pump, Fuel Console, Pump Bracket
    By 67softwindow in forum For Sale: 911 Parts
    Last Post: 09-14-2013, 06:23 PM
  2. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  3. Replies: 10
    Last Post: 08-13-2009, 02:48 PM
  4. 70-71 2.2 911E Mechanical Fuel Injection pump/stacks MFI
    By VintageExcellen in forum For Sale: 911 Parts
    Last Post: 03-06-2007, 07:06 AM
