We have a Becker Europa with terrible reception- this with the new hirschman export market 4 ft tall antenna.
Any ideas on what to look for ? repair? Who is the best in usa to go thru one asap ?
Dave
Dave
Member #755
Conda Green 70 911S
70 black 914-6 3.2
70 911 "Speedster" project
"74 IROC" tribute Jade Green RSR
OEM Repair:
http://www.beckerautosound.com/Classic/index.htm
Definitely worth it IMHO.
Olin - Member #1375
1972 911T
Original
Options added
Send and email to www.oldautoradio.com and see if he can help or make a repair.
RGruppe member 445
Dave...if you need it ASAP, send it to Al's Radio here in Pasadena:
Al's Radio
1531 E Washington Blvd
Pasadena, 91104
626-7945318
He's done ALL of Rusnaks' radio stuff for over 30 yrs.
[FONT="Lucida Sans Unicode"]
Curt Autenrieth
S Registry # 152
Porsches:
1.6L 2.7L
1.8L 3.0L
2.0L 3.2L
2.2L 3.4L h20 cooled
2.4L 3.6L air & h20 cooled
3.8L
It could be as simple as tuning the antenna to the radio. Most early radios have an adjustment screw on the side. How you do it is tune the radio to a weak station than turn the adjusting screw in or out to obtain the best reception quality. Not all antennas are created the same.
Porsche & VW Spoken Here
Current cars:
1970 VW Westfallia
1970 911T 9110122445 Burgundy/Tan Numbers Matching
1970 911T 9110121689 Bahia Red/Black parts shell
1971 911T 9111120111 Bahia Red/Black Numbers matching
1972 914 4722916453 Rusty Orange.......;-)
all good tips- thank you!
especially the one on tuning the antenna- i forgot all about that!
will check that out first and report back
thanks to all
db
Member #755
Conda Green 70 911S
70 black 914-6 3.2
Dave,
Europa's have a small pot above the FM button by the tuning knob. That is the only accessible adjustment without opening the radio that I have seen. If you have a MBZ face plate you will see a small black plug that is removable to access it. If you have the smaller Porsche style bezel, then I think it needs to be removed to access it.
With that said, I have no idea what the adjustable pot does... but may be worth the try.
Thomas
Early S Registry #1227
912 Registry
PCA - Sequoia Region
