Results 1 to 8 of 8
Thread: FS: ZF LSD for late 901/911/914 transaxles
    Well, after much thought and deliberation, I'm putting my zf lsd unit up for sale rather than have it collect dust on a shelf forever.
    This is a factory ZF LSD unit and came from a 911/01 transaxle (1970-71) - should fit later magnesium 901, 914 and 911 transaxles.
    Includes lsd unit, correct longer stub axles, longer ring gear bolts - ring gear is not included and will be removed prior to shipping.
    I have not run this unit, but it came from a running transaxle. I'm guessing it could use a refurbish before you put in the effort to drop it into a transaxle.
    Looking for $950 shipped to USA - including lsd, axles and bolts.
    Regards,
    Andrew M
    Andrew, you have a PM.
    1997 993 C4S, Not totally stock
    2015 GTI
    1991 E30 M3
    1970 911T, Lilly. Slate Gray 3.2ss PMO etc Sold!
    http://forums.pelicanparts.com/porsc...ect-lilly.html
    Early S Register Member #1386
    old softie67S
    Feb 2007
    Sanibel Fl
    I would love it
    If it is not spoken for, I would love to buy it
    Tom
    Tom
    67S soft rear window
    60 356 Cab
    70 914-6 3.2 short stroke twin plug
    05 Audi S4 Cabrio (commuter)
    05 Audi Alroad (family driver)
    Aprilia SR 50R (Sanibel scoot)
    Tom, I pm'd him that I wanted it but can only give a deposit now and need a few weeks to pay for it if thats ok. It will be the perfect addition to my 1970 restoration that Im keeping forever...as long as he can wait a few weeks. If not it is probably yours....but I hope not
    2015 GTI
    1991 E30 M3
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Lsd
    Any identifying numbers on the stub axles? I have a bellieved to be 70/71 S transaxle and would like to know if it has a LSD unit inside.......Perhaps the transaxle number it`s self would tell, too? Cliff
    Carrerax - You are #3 in line right now, but yes if #1 and #2 pass, I'd take the terms as you set out.
    tomkirkcis - Hi Tom - you are #4 right now - I'll keep you posted.
    cliffandropoff - Hi Clff , the easiest way to check would be to lift the rear of the car and in neutral, rotate on wheel - if the other side turns in the same direction, it has LSD - if it turns in the opposite direction, it's open.
    I can get some pics and masurements of the different of the stub axles as well for you
    Regards,
    Andrew M
    Oct 2008
    Burford, ON, Canada
    Andrew, I'll bet Grady Clay would love you to measure the drive flange at each step from the CV face to the top of the splines. Basically document the H out of it. There seems to be very many variations that are poorly documented, especially the correct LSD flanges.
    Mar 2006
    8903one
    Quote Originally Posted by andrew15 View Post
    Regards,
    Andrew M
    I just checked & it is an open differential ! Thanks for the know-how, it will come in handy someday.Cliff
  1. Late alternator for my 67S
    By silveranger in forum Technical Info
    Last Post: 05-19-2008, 10:33 AM
  2. WTB: Screwdriver for late '73 911.
    By Torque in forum For Sale: 911 Parts
    Last Post: 09-20-2007, 07:47 PM
  3. FS Late 73 tool kit
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 03-04-2007, 03:18 PM
  4. FS: 15 X 6 Fuchs / late
    By typ901 in forum For Sale: 911 Parts
    Last Post: 02-01-2006, 11:49 AM
  5. Transaxles
    By naderaggravater in forum Technical Info
    Last Post: 11-26-2005, 09:02 AM
