Thread: WTB Wiring Harness for TTG lights part number 911-612-073-00
    I am about to install my TTG fog lights to my 73 911 and found out, from a fellow S Registry member, that I need the oem wiring harness. The part number is 911-612-073-00.
    Does anyone have one for sale or know how I can purchase one?
    RGruppe member 445
    Ttg lwb
    Parts:
    911-612-026-00 is the cable harness to the switch, 911-612-073-00 is the relay holder that plugs onto the relay area next to the horn relay with the proper wires to the fuse panel.
    First number is available through the dealer but must come from Germany; second number is NLA according to dealer.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    Flunder thanks for the help.
    You are indeed correct about this. I, also found out that I need two seperate wires.1) 911-612-027-00 unknown wire and 2) 911-612-027-01 ground wire.
    Please see my thread "wiring harnesses for TTG lights" in the technical section. There are some solutions, but man do I need help and cooperation to get this one done.
    RGruppe member 445
  1. TTG Wiring harness part numbers?
    By kentf14 in forum Technical Info
    Last Post: 12-30-2012, 08:16 PM
  2. Replies: 2
    Last Post: 10-22-2012, 08:53 PM
  3. FS: 73 wiring harness
    Last Post: 05-19-2008, 06:42 AM
