Thread: WTB: H4/H1 Chrome Mounting Screws Plus Other Items
    Aug 2006
    Chicago area
    So I found out today that the H1/H4 chrome mounting screws were superceded by Porsche and replaced with black ones. Now, that won't look good on chrome rings! So, I need a couple... Anybody have two nice ones they would part with? Thanks.
    I also need the knurled knob to reset the trip ODO and the front torsion bar cover that attaches to the front of the A-arm. Probably should just call Easy, but I thought I would try here first.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Scott, I am in the same boat as you. I have a perfect set of H1's and I need the correct screws. I ordered a set from Pelican and they were the ones with the plastic insert. Then I saw your post and was going to order the other ones and saw that yours came in wrong. I know that the local Ace has a huge selection of Metric stainless phillips machine screws with all different types of heads. Im going to go tomorrow and see if they have some that will work. I will let you know what I find. If anyone stumbles across 4 original ones I would also like 2 after Scott of course.
    1997 993 C4S, Not totally stock
    2015 GTI
    1991 E30 M3
    1970 911T, Lilly. Slate Gray 3.2ss PMO etc Sold!
    http://forums.pelicanparts.com/porsc...ect-lilly.html
    Early S Register Member #1386
    I went to Ace hardware and found a good selection of SS Philips machine screws. I bought some M5 (Original size) and some M6 (In case one of mine is loose and I need to tap it out). I will see tonight how the head fits in the hole in the trim ring. They cost $.56 for the M5 and $.65 for the M6. They are flat head but since they are stainless they could be sanded to a small radius to look better. The problem is that I dont know what is correct. On the pic on the left is the Porsche one (PN 911 631 033 00) then the M5 in the center and the M6 on the right. Scott, I will gladly drop some if these in the mail fo ryou Scott if you let me know what you want.
    2015 GTI
    1991 E30 M3
  1. H1/H4 Mounting Screws??
    By t6dpilot in forum General Info
    Last Post: 10-03-2012, 07:22 PM
  2. WTB Headlight Mounting Screws for 67
    By juche_namja in forum For Sale: 911 Parts
    Last Post: 09-14-2012, 12:58 PM
  3. WTB: H4 Chrome Rings and adjusting screws
    By NickP in forum For Sale: 911 Parts
    Last Post: 07-13-2011, 10:36 AM
  4. 71 qtr window hinge/mounting screws?
    By X-Faktory in forum Technical Info
    Last Post: 06-29-2009, 09:11 AM
  5. Any particular screws to use for mounting rocker trim??
    By wolfturbo in forum Technical Info
    Last Post: 12-23-2003, 08:42 AM
