Thread: Chrome Trim on Dash - '68 L
    Jun 2003
    Bend, Oregon
    I think this is the same with later years as well.
    The basket-weave panels on the dash appear to be sandwiched by the thin chrome (chrome appearing anyway) trim strips on the tops and bottoms. Couple of questions:
    (1) Are the strips glued to the basket-weave material and then the entire panel glued to the dash?
    (2) I have the basket-weave material - are the chrome strips available?
    Thanks for your help.
    Cheers,
    JohnA
    Quote Originally Posted by jaudette3 View Post
    Cheers,
    JohnA
    It is polished aluminum. The aluminum is a flat piece with a thicker edge top and bottom forming the "strips". There is a small groove on the inside edge of the "strips" that the basket-weave extends into. The is also how the radio delete plate is - a thin steel plate with basket weave glued to it that slides into the grooves and covers the cutout in the aluminum where the radio goes.
    The aluminum is attached to the dash with double sided foam tape about 5/16" wide and 1/16" thick. I have seen the aluminum for sale here in the parts section.
    http://www.early911sregistry.org/for...ight=Dash+Trim
    I might have some of the pieces but probably not all and not NOS.
    Don
    912 Registry Charter Member #68
    Flo - 69 912 Targa - Champagne Yellow
    Jack - 69 912 "R" Coupe - Terrorist Tangerine
    Bill (as in William "Refrigerator" Perry) - 97 E350 Powerstroke - White - (P-car puller deluxe)
    Kermit - 04 John Deere 4310 4WD - is there another color?
    Tony - 60 Buick Invicta 4-door hardtop
    Jun 2003
    Bend, Oregon
    Don - thanks for the input. My car looks to be a bit different than what you describe. The aluminum (thanks) strip on the bottom is one piece that goes all the way across - there is no seperation for the glove box door. Does a '68 have one piece fascia that covers the entire dash?
    Also, do you know where to obtain the aluminum strip or maybe the best way to fabricate it?
    Cheers,
    JohnA
  1. FS: Aluminum Dash Trim – Dash Fascia – From a ’71 911
    By m1franck in forum For Sale: 911 Parts
    Last Post: 11-05-2013, 11:30 AM
  2. SWB Chrome trim parts
    By letsrollbabe in forum For Sale: 911 Parts
    Last Post: 03-15-2008, 10:47 AM
  3. Source for chrome trim?
    By berettafan in forum General Info
    Last Post: 05-10-2006, 03:13 PM
  4. Replies: 4
    Last Post: 08-24-2004, 06:36 AM
  5. Chrome sill trim
    By gulf908 in forum General Info
    Last Post: 07-13-2004, 09:10 AM
