Results 1 to 10 of 13
Thread: Rusted Nuts
    Sunshine State
    Rusted Nuts
    From a friend:
    Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
    Penetrating Oil Type ..... Average Load to Free
    None ....................................... 516 pounds
    WD-40 ..................................... 238 pounds
    PB Blaster ................................ 214 pounds
    Liquid Wrench ........................... 127 pounds
    Kano Kroil ................................ 106 pounds
    ATF-Acetone mix..........................53 pounds
    The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch and we all now use it with equally good results. Note also that "LiquidWrench" is about as good as "Kroil" for about 20% of the price.
    Now I know what to do with the nearly 2 gallons of used ATF out of my other car. Make 4 gallons of "rusty-nut breaker"
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Dec 2004
    SE Michigan
    good to know...and I just bought a can of PB Blaster.
    Bill G.
    EarlyS #718 | RGruppe #437
    Sunshine State
    The minimal difference between PB Blaster and WD40 is surprising! Although I can't ever remember using PB Blaster and saying, 'wow, that really worked well.'
    Dec 2004
    SE Michigan
    And I'm assuming no toxicity for the 50/50 mix beyond what is typical of the others.
    Bill G.
    Oct 2003
    Rhode Island
    Quote Originally Posted by 911scfanatic View Post
    You don't want to drink the acetone, but we give the kids atf for scratchy throats.
    Interesting chart, good to know. I wish I didn't have a whole gallon of PB Blaster in the garage though - dammit.
    "Our local machinist group" ?? I knew it was only a matter of time after you got that Bridgeport milling machine......
    '74 leichtbau
    "Sascha"
    R Grp 246
    S Reg 823
    Senior Member BBausser's Avatar
    Jul 2004
    Sutalle, Ga.
    When you buy the acetone you will have to fill out all the DEA paperwork. Looks like amazing results.
    Currently:
    67 3.6 Rocket "Silver"
    62 T6 Outlaw Coupe "ole Yellow"
    65 F100 Custom Cab Flairside Shortbed
    Gone but not forgotten in last 2 years:
    67S Concours King
    67 912 Vintage Racer
    68 912 Flipper
    83 911SC
    93 Mo30 968
    too many cars before that
    Early S Registry # 787
    R Gruppe # 551
    "its better to wear out then rust out"
    Very interesting.
    There is still nothing like heat though. Even the crustiest heat exchanger nut comes right off when it's bright red.
    Tom F.
    '67 911S Slate Gray
    '92 964
    #736
    Jun 2003
    Bend, Oregon
    Yeah, but nothing in the garage smells as good as Kroil.
    Cheers,
    JohnA
    Hey, what about Rost Off??
    I agree, nothing beats a little heat with a handheld propane torch. Creeeeeeaaaak.
  1. new project - i must be nuts
    By advtracing in forum Other Porsche Passions
    Last Post: 05-07-2012, 09:14 PM
  2. For Alfa nuts
    By Mark Morrissey in forum Off Topic
    Last Post: 01-19-2010, 09:42 AM
  3. Gas Burners - what to use for nuts?
    By W6CZ in forum Technical Info
    Last Post: 11-30-2008, 03:01 PM
