Results 1 to 7 of 7
Thread: FS- Used 906/911R Flywheel & Pressure Plate
    Senior Member 72tii's Avatar
    Nov 2004
    Bedford, TX
    Flywheel is flat and appears to be in good, usable condition.
    Pressure plate was working when removed over 25 years ago. Fingers on the diaphragm show wear where they contact with the release bearing.
    Diaphragm can probably be replaced by KEP. Obviously, the cover is drilled for lightening- not so obvious is that the "foot" is also drilled.
    The "foot" --the piece that contacts the clutch disc--is not aluminum.
    I have included a photo from Bruce Anderson's 911 Performance Handbook of a 906 engine for reference.
    $2500 or best offer for both.
    1968 911 #11830241
    Early S Registry #810
    R Gruppe #461
    Hi,
    not sure the flywheel is a 906/911R,seems to be a ligthened early flywheel.
    Sep 2006
    La Quinta
    It looks like a 906...I have the set just like it, except the one I have was not copper faced.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    I agree with Oliver - the 906 flywheels that I have seen have more holes in them than Dutch cheese This looks like a lightened 901 flywheel - you can't drill too many holes into them otherwise they brake/crack. A 906 flywheel also has holes drilled around the pulley.
    Sep 2006
    La Quinta
    You you what...you guys are right. The one I have does have has those holes. I remember that now. It's on the car so I can't take a look at it.
    Registry #983
    R Gruppe #741
    Jan 2003
    UK
    Olivier's right - here's a 906 flywheel I sold earlier this year:
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Nov 2004
    Bedford, TX
    Thanks for all the replies. I stand corrected on this flywheel- sorry about that.
    What do you guys think this setup is worth?
    1968 911 #11830241
    R Gruppe #461
  1. 906 flywheel, clutch, and pressure plate?
    By JPlonghood in forum Technical Info
    Last Post: 11-12-2009, 03:48 AM
  2. FS - 2.0L clutch/pressure plate/flywheel
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 09-24-2009, 12:28 AM
  3. 69 S alum press plate and nos flywheel
    By dave in forum For Sale: 911 Parts
    Last Post: 09-05-2006, 10:09 AM
  4. FS:906 911R 911S flywheel
    By OliveR in forum For Sale: 911 Parts
    Last Post: 09-30-2005, 02:29 AM
