Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: RSR Sway Bars
    RSR Sway Bars
    Tarett Engineering has come up with a sway bar assembly that comes pretty close to duplicating what was used on the 73 RSRs. Here is a link to show what it looks like, and pricing. Ira at Tarett makes high quality sway bars, and these should fill a need for those of us who like to use period looking hardware.
    Gib
    http://www.tarett.com/items/911-seri...914-detail.htm
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Scope Creep Poster Child
    May 2003
    Eugene, Oregon
    Those look nice. Nothing red on them!
    Early S Registry 1047
    ’15 VW GTI
    '70 911E, Sold
    '56 Cliff May Prefab
    I think Ira is planning to use what he calls a 'silver' anodizing on the blocks/collars, drop links, and most likely the lever arms. This is what he used on the parts he supplied for my Kremer ST, and they look more like a medium grey color.
    I used my own custom built lever arms which were powder coated. The collars in the rear will now be grey and not bright as shown on my car.
    Gib
    PS: I have no affiliation with Tarett.
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    Hats off
    A round of applause for letsrollbabe - he made it happen!
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    May 2003
    Eugene, Oregon
    Are these bars too much for a street car?
    ’15 VW GTI
    '70 911E, Sold
    Scott:
    They function just like the standard Tarett sway bar assembly as the levers are approximately the same length. Uses the same hollow bar and blocks/collars. The drop links are different, but that doesn't affect how they function. They look pretty cool when you see them hanging down from under an early car.
    Gib
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    May 2003
    Eugene, Oregon
    Gib-
    I gather that they are a 22mm bar, which might be a little bigger than I would otherwise choose. Do you think that on the softest setting I might get something appropriate for a narow bodied car driven aggressively on the street in an area with less than perfect pavement? My alternate choice might be Smart Racing Products 20mm bars, but these look more correct.
    By the way, great car you have!
    ’15 VW GTI
    '70 911E, Sold
    Scott:
    Tarett states that their bars are the same stiffness as solid 22 mm bars, so they would be more aggressive than a stock 15 or 16 mm bar. The softest lever hole might be slightly longer (6.5" vs 6") than the factory bar lever which will soften the difference somewhat for the rear. On the front, the Porsche stock lever is approx. 4.75", so these levers (at softest setting) would tend to offset the difference in stiffness even more between a 15 or 19 mm bar and the 22 mm Tarett bar.
    Gib
    Gib Bosworth
    EarlySReg 434
    R Gruppe 17
    May 2003
    Eugene, Oregon
    Thanks, Gib. Time for me to do some math.
    ’15 VW GTI
    '70 911E, Sold
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    Drop link connect!
    Will the droplink connect to the control arm or the spring plate?
  1. Which Sway bars?
    By Veronica87911 in forum Technical Info
    Last Post: 11-19-2013, 06:19 PM
  2. RSR Sway Bars
    Last Post: 08-22-2012, 11:29 AM
  3. WTB: H&H sway bars
    By Flat Six, inc. in forum For Sale: 911 Parts
    Last Post: 02-12-2008, 02:12 PM
  4. Sway bars
    Last Post: 10-14-2005, 04:34 PM
  5. sway bars
    By Ivs in forum Technical Info
    Last Post: 01-22-2005, 08:55 AM
