Results 1 to 9 of 9
Thread: Rehab of front chassis ID plate
    I'm wondering if anyone has a lead on what options exist for sprucing up the front chassis ID plate. Not looking to fake anything, but mine is pretty scruffy, and the car is hoped to be just about perfect otherwise when it's done. Thanks, Bill Morris
    Bill Morris
    Sep 2006
    Eagle, Idaho
    Bill,
    after drilling out the rivets and removing the original from the car I cleaned it with an old toothbrush dipped in laquer thinner. Even that rudimentary first step was a notable improvement. Then I took it to a friends house who has a sandblasting cabinet , but it is filled with the finest sand which has been used a long time and is no longer very aggressive. That's really important because you do not want to texture the plate, you just want a uniform surface finish that does not impart its own character. Next I experimented on a couple of old junk ID plates I had laying with various abrasives until I liked the result, and that occured when I gently rubbed the plate with # 0000 steelwool. Do not use sandpaper or a Scotch-Brite pad since you will remove plate material and flatten the letters. Use only straight left to right, right to left strokes with the plate on a flat, hard surface until you get exactly the look you desire.
    After that, I think using a fairly fine, long, flat new file to make sure the edges are straight with uniform, neat & matching corners adds greatly to the crispness and new appearance.
    The toughest part will be straightening the half-round bead that surrounds the plate like a picture frame if it is damaged. For that, use a piece of round soft wire, (soft wire so you can bend it for the corners) the diameter of which matches the inside diameter of the bead and gently tap with a small hammer until you have restored the bead as best you can. Be very careful & work slowly & methodically, this material is extremely soft and thin and mars very easily. You'll never get a kink out. The corners may require filing and shaping of the wire..... Patience!
    Alum. ACE hardware rivets finish the job.
    Photo of my restored per-above, original plate after I finished with it, attached.
    Good Luck,
    JZG
    Thank you. Bill M
    Bill Morris
    nice job john!
    bob moglia
    '72 E sunroof coupe
    Dec 2006
    Las Cruces, New Mexico
    If using media blast turn regulator down to aroud 20- PSI.
    Early 911S member #166
    Sep 2006
    Eagle, Idaho
    Quote Originally Posted by MarkS View Post
    Very important & useful suggestion. Sorry I neglected to mention it. In fact, to be double safe, if I were to do this again, I would use crushed walnut shell and not use any mineral product at all.
    Thank you very much, Mark.
    JZG
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Soda Blast, it won't affect the plating
    http://www.aircooledtech.com/tools-o.../soda_blaster/
    Tony
    #1704 58cab's Avatar
    Nov 2002
    Mountain View, CA
    Quote Originally Posted by classic View Post
    Tony
    Threadjack:
    Thank you for that tip! Would that set up work with other media also? (not on carbs)
    Mike
    Nov 2004
    Gold Coast.
    Mike,
    Can't see why not.
    I've got a dedicated media blaster, but i can't run Soda through it.
    If you are going to utilize this for anything, please use a good quality respirator and a full face shied, as it will go everywhere.
    Tony
  1. Rudy's Rehab
    By FL-Frank in forum General Info
    Last Post: 07-09-2015, 07:33 AM
  2. Original 73 front chassis paint (I think)
    By Mark Wilson in forum Technical Info
    Last Post: 01-21-2014, 10:22 AM
  3. FS : Unstamped Chassis number plate and Red-frame stickers..
    By andrea70 in forum For Sale: 911 Parts
    Last Post: 02-22-2012, 07:50 AM
  4. Fuel System Rehab
    By lwalwa in forum General Info
    Last Post: 05-15-2007, 06:48 PM
  5. Blank chassis plate
    By porkers 912 in forum For Sale: 911 Parts
    Last Post: 07-21-2005, 05:52 PM
