Results 1 to 7 of 7
Thread: FS: Mahle 2.8L RSR Pistons and Cylinders
    ~~~~~ SOLD ~~~~~
    Mahle 2.8RSR 92mm Pistons and Cylinders : $2000 obo + shipping
    Used but look like new. Little/no play in rings. No bent/broken fins. Match with 66mm crank to make a 2.6L short stroke.
    Ring gaps measured to within *new* specs!
    Dec 2004
    SE Michigan
    So the cylinder head stud spacing on these is the "regular" case spacing and not RSR spacing, correct? My understanding is that RSR engines and stock engines have different stud spacings.
    What is the compression ratio?
    Bill G.
    EarlyS #718 | RGruppe #437
    Head stud spacing is 'regular', ie, works with 7R case. You will need a large spigot case (I have two that I'm selling as well) or will need to have the spigots opened up on a small spigot case. If you have a small spigot 7R case, you'd be better off selling it and buying a large spigot case.
    They are 10.3:1 C/R when used with larger RSR heads. A 2.4/2.7L head will require some machine work to lower the compression for use with pump gas. Steve Weiner at Rennsport is very familiar with this.
    Aug 2007
    Phila Pa. area
    Stud spacing
    Quote Originally Posted by 911scfanatic View Post
    The 2.8 RSR uses 80mm head stud spacing, same as street engines. The 3.0 RSR uses 83mm head stud spacing. An SC engine uses 86mm spacing.
    Mike
    this is a good deal...
    If I was building a short stroke something....these would be perfect...wait, I'm looking for 2.0 S stuff. Someone should snag these...
    Speedo
    registry# 1283
    Registered User parced@telia.co's Avatar
    Apr 2005
    92 mm
    I'm interested. Please contact me on parced@gmail.com.
    Regards,
    Pär
  1. NIB/NOS RS 2.7L Pistons & Cylinders Mahle
    By Longballa in forum For Sale: 911 Parts
    Last Post: 12-23-2015, 01:51 PM
  2. FS: 2.7RS Mahle Pistons/Cylinders
    Last Post: 08-07-2010, 04:16 PM
  3. Mahle 2.4S cylinders and pistons €2.950
    By Leonard Stolk in forum For Sale: 911 Parts
    Last Post: 11-02-2009, 01:16 AM
  4. '67/68 S Mahle pistons and cylinders F/S
    By JPlonghood in forum For Sale: 911 Parts
    Last Post: 03-17-2009, 06:11 PM
  5. F/S: Mahle RS Pistons and Cylinders - $875.00
    Last Post: 12-17-2008, 03:51 AM
