Results 1 to 7 of 7
Thread: steering wheel removal?
    Does anyone know the size of the steering wheel nut on a 66 911?Heading out to buy a socket the right size but have no idea which size to get..my current set goes up to 24mm..Thanks.
    Jan 2003
    UK
    There were 2 sizes of nut used - 24mm & 27mm.
    If your 24mm socket is too small you must have the 27mm nut.
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Thanks andy..Yeah the 24mm is too small.
    I use american size 1 1/16" deep, works well
    Apr 2003
    Portland, OR
    BTW - When you go to loosen the nut be sure you are pushing down. You do not want the wrench handle to fly up and break your windshield. Also, be sure you have something to hold the steering wheel so it does not turn. I am not sure if your 66 has a steering column lock but do not use that to hold the wheel steady as you loosen the nut.
    Harry
    Member #789
    2009 MB C300
    Leave the nut on about 3-4 thread when you break it free. This will assist in keeping your nose on your face when you start pulling on it to remove it.
    It's happened more than a few times. Busted lips, noses and foreheads.
    Tom
    Early S Registry #235
    rgruppe #111
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Tom,
    Ouch.... I must admit i just visualized this and had a giggle..... Sorry
  1. Steering wheel nut removal
    By BrentF in forum Technical Info
    Last Post: 04-24-2013, 10:20 AM
  2. Steering wheel removal
    By luke-44 in forum Technical Info
    Last Post: 04-07-2013, 04:36 PM
  3. Steering wheel removal??
    By Zuffenhausen in forum Technical Info
    Last Post: 11-27-2009, 12:15 PM
  4. Steering Wheel Removal
    By roray in forum General Info
    Last Post: 05-09-2009, 02:52 PM
  5. 73.5 steering wheel removal....help!!!
    By KJensen in forum Technical Info
    Last Post: 10-26-2005, 01:00 PM
