Results 1 to 9 of 9
Thread: Battery fumes and aluminum. Any chemists out there?
    Odd problem. My battery is held in place with an aluminum strap. Fumes from the battery vent seem to be eating the aluminum! Left untouched for 3-4 weeks, the aluminum next to the vent is covered with a baking soda-like powder. Anyone encountered this problem? Would powdercoating the aluminum help?
    jhtaylor
    santa barbara
    I would expect acid fumes to corrode any metal in that situation. I think powder coat would help but you should just keep an eye on it, clean it occasionally, and replace the strap as necessary.
    You betcha!
    Acid plus metal makes for hydrogen gas and the oxidized metal. Classic 'popping dog' experiment in freshman chemistry. Dilute HCl or sulfuric acid and toss in some aluminum or zinc, cover with thumb while bubbling, then release near a bunsen burner.... "pop" goes the hydrogen in to water.
    L
    Thanks.
    Yup. Corrosion is what I have. What to do? Will powdercoating or paint hold it at bay, or am I condemned to cleaning the surface every week until I can mount some different kind of battery?
    jhtaylor
    santa barbara
    Oct 2008
    Burford, ON, Canada
    powder coating seems to be a bit porous and the acid would tend to cause damage under the coating before it erupted into blisters.
    I'm thinking duct tape, or maybe a plastic tape might do the trick. I'll experiment a bit and report my results.
    jhtaylor
    santa barbara
    Battery Fumes
    If you have to clean off the aluminium sulphate every couple of weeks then it sound very much as if you have other issues with your battery and charging circuit.
    I would check battery temperature and look at the regulator as well.
    Ideally, you want to vent the fumes to the outside, this is not always possible - unless someone has a open hole to run a hose to. The other option which is easier, just let her sleep with the hood open.
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Hmm. Voltages in the car suggest the charging circuit is working normally but you raise an interesting point. I think we'll have the regulator checked. It's interesting I've not seen this on a car before.
    jhtaylor
    santa barbara
  1. Fumes From Heater
    By JohnnyO in forum Technical Info
    Last Post: 10-30-2007, 05:08 PM
  2. Removing fumes from gas tank?
    By TWork in forum Technical Info
    Last Post: 04-24-2007, 08:02 AM
  3. Exhaust Fumes???
    By VIper Green E in forum Technical Info
    Last Post: 03-31-2006, 09:10 PM
  4. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 09:44 PM
