Results 1 to 10 of 16
Thread: Fender Repair
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Fender Repair
    For those of you interested i repaired my lower fender yesterday.
    This is what can be hiding behind your S rocker trim, and some 80's resale red paint.
    Nov 2004
    Gold Coast.
    After some bending welding, and some words of persuasion
    Nov 2004
    Gold Coast.
    The gaps are good, and this is starting to look better than i expected after i had to replace both inner outer rockers, jack point, the fender support, bottom of the A pillar, and not to mention the bottom of the longitudinal
    looking good!
    bob moglia
    '72 E sunroof coupe
    Feb 2003
    Los Angeles
    Sounds like a lot of work. Can you show some photos of what you repaired on the bottom?
    Thanks for sharing.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Nov 2004
    Gold Coast.
    Thanks Bob, that means a lot coming from you.
    Now i just have to talk you into another visit to Australia so you can help me paint it.
    Burt, sure thing, caution not for the faint hearted.....
    The normal rust bubble under the lead joint.....
    Nov 2004
    Gold Coast.
    Only the inner and outer were affected. mainly from the panel being replaced and the drain holes at the base of the rocker sealed with seam sealer, including the base of the A - pillar.
    Nov 2004
    Gold Coast.
    And the outcome after some head scratching
    Nov 2004
    Gold Coast.
    Rear end is now complete things left to do, small patches on the opposite fender including the mounting flange, and the suspension pan and support.
    Nov 2004
    Gold Coast.
    Oops forgot the photo
  1. NOS inner fender repair piece 911 501 017 -0
    Last Post: 10-17-2012, 02:58 PM
  2. WTB: Right hand fender extension - to back date later fender
    By Andy 74 in forum For Sale: 911 Parts
    Last Post: 06-19-2012, 04:50 PM
  3. Can I repair/replace fender bracket mount on battery box?
    By mobius911 in forum Technical Info
    Last Post: 04-14-2012, 08:48 PM
  4. FS-SWB NOS fender repair panels
    By jojogto in forum For Sale: 911 Parts
    Last Post: 01-15-2009, 06:16 PM
  5. Front fender conduit panel repair
    By Neil '67 911S in forum Technical Info
    Last Post: 09-22-2008, 05:26 PM
