Results 1 to 7 of 7
Thread: Correct tire size
    Senior Member Varooom's Avatar
    Oct 2006
    SoCal
    Correct tire size
    I need the correct tires size for a '73 911S I am working on. The wheels are correct 6" Fuchs. This car is getting put together factory correct. Thanks.
    Steve Var.
    _____________
    61 356B
    67S
    66 912
    66 Fulvia
    72 914
    Correct tire size
    That car would have had 185 x 70's
    Oct 2006
    SoCal
    Thanks.
    The correct Michelins were $450.each!! Just bought 4 new Vred's Classics@ $120.each.
    Steve Var.
    _____________
    61 356B
    67S
    66 912
    66 Fulvia
    72 914
    I think you can get these somewhere in between the two prices and they were OE.
    Pirelli Cinturatos
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
    Sigh. . . when is somebody going to start molding Firestone "Phoenix" tires?
    These were made by Phoenix Gummiwerke which is now part of Continental. (now schaeffler group)
    I finally decided compromise is the only alternative and went with these:
    2 215/60R-15 Bridgestone Potenza RE960AS Pole Position $61.00/ea $122.00
    2 195/65R-15 Bridgestone Potenza RE960AS Pole Position $79.00/ea $158.00
    Kenik
    - 1969 911S
    - 1965/66 911
    - S Reg #760
    - RGruppe #389
  1. tire size rsr 73
    By gwilliams in forum Technical Info
    Last Post: 12-08-2011, 06:01 PM
  2. Best tire size for a 73 with 7s ??
    By Rennman in forum Technical Info
    Last Post: 07-13-2011, 10:25 AM
  3. correct tire size for 1972 911T
    By Perry911 in forum Technical Info
    Last Post: 01-11-2009, 04:11 AM
  4. 67S tire and size
    By mwilson3003 in forum Technical Info
    Last Post: 09-03-2007, 09:42 AM
  5. Best Tire Size for a '72 S Targa
    By RC70SCoupe in forum Technical Info
    Last Post: 09-26-2006, 05:55 PM
