Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: I have been caught AGAIN.......Just quickly
    Senior Member ST Man's Avatar
    Pretoria, South Africa
    I have been caught by this one before and yet again I fell for it. I received a bump on my bonnet so I have to respray the bonnet...but it is a silver car so I have to blend in the paint to the two fenders, bumper and wiper panel.....that is 5 panels on a car that has 12 in total. Why dont I respray the whole car it is 40 years old. Then I can remove the rust around roll bar.....then......then then then o yes the rubbers are old and the roof in leaking then I can redo all the vinyl then.... then then O MY SOUL IT CAUGHT ME AGAIN
    The damage to bonnet is what happens if you park your car behind a BMW X5 that cant see the little car behind it when it reverses. That was the tow bar.
    The car as it looks now. I had a found a spare bonnet and also found alot of rust. All this is now welded up, I will add pictures later. The car have a lot of rust around roll bar and in floor but the rest of the car is amazingly clean???
    The floor took me 8 hours from from pic 1 to 4. It cleaned up real well and had surface rust only. One job donw lots to go
    Wow, all that just from a little bump on the hood (ooops, bonnet) Nice work though, looks like just in time for that rust under the roll bar.
    Aug 2006
    Chicago area
    Wow, talk about the "may-as-wells." Good luck with the project.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    This is taking long....
    Well the rusted areas under roll bar are fixed and just need some finishing. I went to a very good body shop and asked for a lesson in working with lead. So I made new panels welded them in and then finished it with lead.
    I need some advise as well I want to replace my front fenders because according to me the 68 cars did not have a lip around wheel arch and was just straight. I have both sets and they fit. What is correct fender.
    911 S Targa 68 11850243
    911 S 69 #119300002 Ex Dr.F Porsche
    911 ST Replica 72
    59 VW Deluxe Microbus 23 Window
    58 Durkopp Diana Scooter
    Apr 2004
    Quote Originally Posted by ST Man View Post
    How did you get from 1-4 ?
    What process/tools/materials did you use ?
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    Those look like 69 or later front fenders. I think the lip shold be about the same as the rear. Earlier cars were flater. The front fenders on a 68 are another one of those one year only things on a 68. The front signals (one piece) and horn grills (wider) are different then what you have if those are LWB fenders, as are (at least on US spec cars) the light buckets, different from earlier cars I believe. But looking at the first photo they horn grills and signals look like they are correct for a SWB. So I am not sure WHAT you have.
    Oh what a slippery slope you encountered.
    Don
    912 Registry Charter Member #68
    Flo - 69 912 Targa - Champagne Yellow
    Jack - 69 912 "R" Coupe - Terrorist Tangerine
    Bill (as in William "Refrigerator" Perry) - 97 E350 Powerstroke - White - (P-car puller deluxe)
    Kermit - 04 John Deere 4310 4WD - is there another color?
    Tony - 60 Buick Invicta 4-door hardtop
    Can you post more images of the repair at the roll bar on each side. Thanks.
    Mark
    1973 911T Targa 3.2 hot rod - Sold
    1992 964 C2 - Sold
    1988 VW Single Cab Truck - For Sale
    1985 VW Double Cab Truck
    ABOUT THE FLOOR
    It had alot of surface rust but no penetrated rust that messed floor pan up. What I did is I took a hammer and chissel and removed all the old rubberizing froom the floor. Then I took a drill with a wire brush thing on the front to clean out the corners and also an orbital sander for flat areas. I cleaned up every piece of rust of the car as far as possible. After vacuming the car I used a rust inhibitor named deoxidine. This stuff works great if you apply it for 20 minutes make sure it stays wet. Thenwash it of with water. DRY OF THE WATER before it car rust DONT LEAVE WATER!!!!
    THE ROLL BAR
    The rust was right through the roll bar at some places so I made a new plate and supported the bar along the lenght on both sides. I then made new panels for for right behind door and where rear window seals fits. They were welded in and then I used the lead to get a good finnish
    911 ST Replica 72
  1. It's about time we caught up with the ROW
    By 50/50 in forum Off Topic
    Last Post: 12-04-2013, 03:36 PM
  2. caught in traffic....no problem, swim around it !!
    By John Z Goriup in forum Other Car Cultures
    Last Post: 06-20-2012, 07:27 AM
  3. 998 caught testing
    By Flieger in forum Other Porsche Passions
    Last Post: 12-01-2010, 05:34 PM
  4. As Long As You Don't Get Caught...
    By sithot in forum General Info
    Last Post: 08-22-2010, 11:08 AM
