I have followed this post with some interest.
My ’72 E built in Feb ’72 is just about ready for the color coat. While not a pristine example, it did have the original paint beneath an earlier repaint. While removing the paint to bare metal this is my experience:
1)Underbody – The underbody coating was not removed, so I can’t really say much here. Appears to contain some body colored overspray beneath accumulated dirt associated with years of use.
2)Rockers - The rockers were coated with a factory applied tan/beige material having a fairly coarse texture that was rock hard on top of a light colored seal primer applied to the metal. No external corrosion.
3)Wheelwells - Appears to be a brushed on satin black paint with occasional body color bleed thru. Not sure what underbody coating material was applied here.
4)Front and rear bumpers - A hydrocarbon based (bituminous) undercoating which resulted in substantial ricochet when bead blasted and a tarry mess when paint stripper was applied. I do not know if this was original or not. Given the ease of removal of the bumpers and the material applied possibly not, although the rear bumpers based on other used examples from earlier year model LWB & SWB models could have original undercoating material. On the steel “S option” bumper, a minor amount of surface rust was present beneath the undercoating which may have become an issue over the long term.
5)Underneath the hood, between the stiffening braces - Factory applied tan/beige material having a fairly smooth texture on top of a light colored seal primer applied to the metal. Several coats of paint stripper was required to get to bare metal. Tough stuff. No rust here.
The rocker (and presumably underbody coating) material and the underhood material matched as Dr. Johnson indicated they would for LWB cars in his book. See page 6. Supposedly a PVC type material, this would be consistent with the rockers and underhood material that was removed.
So what am I going to apply prior to the color coat? These are the options that I have considered:
1)Wurth SKS Stone Guard (gray) – A medium gray material that I do not believe is the right stuff. According to the MSDS this contains primarily talc. A water based product, it takes 3-4 days to fully cure. Maybe longer if humidity is high. Requires a special Schutz gun to apply properly. My painter believes painting on top of this is risky business. I have two (2) 30 oz. bottles if anyone wishes to give it a try, one unopened, one slightly used.
2)Wurth Underbody Seal (beige) – According to the MSDS contains a Magnesium-Silica talc (25-35%) an ethenyl benzene polymer w/1,3 butadiene (5-7%) and quaternary ammonia compounds (3-5%) with titanium dioxide (1.5-2%) white paint base. Uses naptha/tolulene solvent.
3)3M Rocker Panel Spray (tan) P/N 05910 - Comes in a spray can. According to the MSDS contains vinyl chloride-vinyl acetate-maleic acid polymer (5-10%), the ubiquitous talc (3-7%) and silica (0.5-1.5%) with ketone solvents.
4)3m Underbody Seal (beige) P/N00874 - Uses a regular rocker Schutz gun to apply. According to the MSDS contains Acrylonitrile-1,3 Butadiene- divinyl Benzene copolymer (5-10%), talc (3-7%), silica in the form of glass bubbles (1-5%) and a butyl phenol-formaldehyde resin (1-5%) in a ketone/toluene solvent.
As can be seen, the bottom three options are worthy of consideration due to the residue materials and the volatile solvents which should give quick cure times. The factory surely would have taken this into consideration just as a custom painter will. It is questionable whether any of these compounds match what the factory used back in the day. As technology changes with time, original materials (particularly complex materials such as these) cease to exist. Thus the saying it is only original once and can’t be duplicated.
So what am I going to use? While I think the 3M Rocker Panel Spray (tan) P/N 05910 may be the closest match to factory if Dr. Johnson’s observations are considered, I am going to leave it up to my painter and his experience with these products with longjevity in mind. Since he has a great deal of experience with 3M it will likely be the 3m Underbody Seal (beige) P/N00874 so the correct texture can be applied underhood with the Schutz gun. Besides, I kind of like the idea of resin holding this stuff together and forming an additional chemical bond on the car.
Robert
