This seems like a very early date stamp to me. Size 4 1/2. Would go on a '64 911, or could it be from another vehicle?
Bill G.
EarlyS #718 | RGruppe #437
Would be in the build period for a 356 C/SC. Started '64 model year with disk brakes.
65 356SC Dolphin Gray
66 912 Green
69 911E Tangerine
72 911T GP White
72 911T Aubergine
72 911T Lilac
72 911S Black (voodoo)
90 964C4 Black Targa
94 964C2 Black Coupe
08 GT3 Speed Yellow
Figured something like that, but I didn't know anything about the 356 bolt patterns, and I forgot about the disc brakes on the C.
I'll list it on the 356registry...does $50 sound about right? I also have two 4.5 5/65 Lemmerz wheels, are those worth about the same? Those could be for a 356 or a 911 too, I suppose?
Bill G.
Bill,
Does it have a 3.7 or a 3.9 on it? The Carreras (and maybe the 911s?) usually used the 3.9s. You can always measure it at the lug flat. It is probably a standard 356 wheel. $50 if not bent.
If it is a 3.9 PM me.
H
What do those numbers, 3.7 and 3.9, refer to?
Early 911S Registry #224
911S Targa 1973
356B Roadster 1962
The thickness of the metal. Porsche was trying different thickness on the wheels from the beginning 356s. (The most famous being the 550 recall wheels that failed around the lugs.)
H
could fit a 904....
As far as I'm aware, 904's never used 4.5 " wheels.
In addition, the wheels used on the 904 models had steel centres rivetted to alloy rims.
Andy
Early 911S Reg #753
R Gruppe #105
The 356 in July 63 a 64 model year car had disc brakes. the bolt patern is the same on a 356 as a 900 series cars at 5x130mm and 14mm lug studs. 15x4.5 inch with a 11/63 date code would be a 356 wheel likely for sure. $50 for an unbent "core wheel" is a fair price and Brad at Stoddard/NLA parts in Reno will buy them all day long.......
Porsche & VW Spoken Here
Current cars:
1970 VW Westfallia
1970 911T 9110122445 Burgundy/Tan Numbers Matching
1970 911T 9110121689 Bahia Red/Black parts shell
1971 911T 9111120111 Bahia Red/Black Numbers matching
1972 914 4722916453 Rusty Orange.......;-)
Current cars:
1970 VW Westfallia
