Thread: Need help with lock post replacement
    I need to replace a lock post as part of my restoration, but can't find any spot welds on the quarter lip. I see them on the interior, but not the exterior. I've ground as much material off as I feel safe doing and tried a torch to see if they're hidden with lead but no success. Now I'm not sure what the right way to do the replacement is. Here is how it looks:
    __________
    Sean
    1971T restoration in progress http://911restorationmadness.blogspot.com/
    1982 PCA club racing #372 D-Stock
    Registry #1595
    I found these pictures of someone's install and it looks like the spot welds should be drilled from the outside:
    __________
    Sean
    Registry #1595
    I would take an abrasive wire wheel to the lip shown. The quarter curves around and lays over the door stricker plate.
    One of those wire wheels usually scrape enough metal off the lip so you can see the spot welds. From the picture it doesn't look like you've cleaned the area enough.
    There is also lead in that area so if you do break out the wire wheel make sure to wear a good mask.
    72T Coupe - hotrod.
    72S "Tangie"
    73S Poop Brown
    69T Irish Green
    69S Secret Project
    S Registry Dues Paying member #1438
  1. 1965/1966 Door Lock Post Question
    By Toffynose in forum Technical Info
    Last Post: 11-07-2013, 07:55 AM
  2. FS: Passenger B pillar/lock post
    Last Post: 11-06-2009, 05:30 AM
  3. Wtb rhs 1972 lock post
    By advtracing in forum For Sale: 911 Parts
    Last Post: 07-11-2009, 07:44 PM
  4. WTB: Early (65/66) door lock post
    By Semjon in forum For Sale: 911 Parts
    Last Post: 07-08-2008, 10:06 AM
  5. Wanted: SWB 1968 drivers lock post
    By Grun68 in forum For Sale: 911 Parts
    Last Post: 04-11-2008, 04:39 AM
