Thread: 906 flywheel, clutch, and pressure plate?
    I was working on my old '69S hill climb car that I purchased off Craigslist today in preparation for starting a new twin plug engine build and found this stuff when I pulled the transmission. Are these 906 parts, or just a '69S flywheel w/ an aluminum 906 type pressure plate and a clutch disk that looks like something I'd use for drag racing (those are 4 solid bronze pads)?
    Yup, I think so. 906 and 911S used a lot of common parts.
    Patrick Motor sports sells something that looks like the flywheel, and it's a genuine Porsche part, but the part number listed is different then mine. They take theirs and drill it to make a 'lightened' 906 flywheel. http://www.patrickmotorsports.com/part/46/
    The timing set numbers on my flywheel are stamped like a 914-6 flywheel, so it got me thinking 906 due to it's mid-engine mounting too. I don't know if I have any '69S flywheels that aren't installed in a car to check the numbers, I will look to see.
    I have figured out the pressure plate is the aluminum type, like a 906.
    Never seen a clutch disk in a 911 that looks like this.
    Mar 2006
    Louisville KY
    I was going thru a stack of 901 flywheels the other day and half of them had the timing marks like the 914-6. I suspect that the replacement flywheels started to all have the timing marks....
    Tony Proasi
    52 split window coupe
  1. FS-NOS 'S' early clutch and pressure plate
    Last Post: 05-29-2012, 11:08 PM
  2. FS- Used 906/911R Flywheel & Pressure Plate
    By 72tii in forum For Sale: 911 Parts
    Last Post: 11-01-2009, 03:55 PM
  3. FS - 2.0L clutch/pressure plate/flywheel
    By haycait911 in forum For Sale: 911 Parts
    Last Post: 09-24-2009, 12:28 AM
  4. WTB - Clutch Pressure Plate SPORTOMATIC
    By tgittens in forum For Sale: 911 Parts
    Last Post: 05-10-2009, 07:44 AM
