Thread: If you were a 911 ST, What Hoosier A6 tire sizes would you wear?
    Senior Member C.Plavan's Avatar
    Mar 2005
    Clovis, Ca
    Let's just say you had 15x8 Fuchs in front and 15x10 Minilites in the rear. What Hoosier A6 tire sizes would your run? What if there was a 15x9 Minilite thrown in also- What size?
    Any ideas or experiences?
    With 8s and 10s:
    23" diameter
    P225/45ZR15
    P275/35ZR15 (if the offset allows tire to fit under the ST flare)
    With 8s and 9s:
    25" diameter
    P225/55ZR15
    P245/50ZR15
    Randy Wells
    www.randywells.com/blog
    www.hotrodfilms.com
    Early S Registry #187
    Mar 2005
    Clovis, Ca
    Edit* I was looking under the A6 instead of the R6- They have the 245 in the R6
  1. Hoosier Tire
    By 50/50 in forum Technical Info
    Last Post: 12-11-2017, 11:16 AM
  2. Track tire wear and heat...?
    By davewadd in forum Technical Info
    Last Post: 08-19-2013, 05:21 AM
  3. SWB Tire Sizes and Swapping
    By B D in forum Technical Info
    Last Post: 07-24-2013, 08:47 PM
  4. Uneven tire wear?
    Last Post: 04-21-2007, 06:27 PM
  5. 73 911 tire/sizes of choice?
    By aracerx in forum General Info
    Last Post: 10-18-2004, 12:47 PM
