Results 1 to 2 of 2
Thread: 70 Targa interior dome light problem
    I have purchased a new dome light since I found the existing to be broken and shorted out, blowing the fuse.
    I replaced the fuse and the clock now works as it is on the same system.
    Now, I'm having a problem wiring the replacement light. There are two wires, one tests with 12.5 volts and the other tests as a ground. The light has 3 spades for wire attachment. One connects directly to the light frame, likely for chassis grounding. One attaches to one end of the bulb holder. One attaches to what appears to be the switch mechanism.
    The bulb check out fine, but when installed in the fixture and the two wires attached, as I believe they should be (power lead to fixed end of bulb and ground lead attached to the switch mechanism) I get no light.
    Can someone describe the correct wiring?
    Help
    Thanks in advance,
    Rob
    356Robo
    64 C Coupe #218448(sold)
    70T Targa #9110110416(sold)
    Senior Member ThomasTe's Avatar
    Jan 2005
    Denmark, Europe
    The black wire (12,5V) connects to the end of the bulb holder. Brown wire (ground) connects to the switch mechanism. When you fit the lamp assembly into the targa bar, make sure the frame of the lamp touches the metal of the cut out to establish a ground connection to the frame. Then the lamp will work as intended.
    Thomas
    1973 911S Targa
  1. FS: OE interior dome/roof lights
    Last Post: 05-12-2012, 02:02 PM
  2. 73 Interior "dome" light correct bezel, chrome or black
    By kentf14 in forum Technical Info
    Last Post: 08-09-2011, 11:07 AM
  3. WTB: Targa Bar Interior Light & Glove Box Light
    By miken426 in forum For Sale: 911 Parts
    Last Post: 07-31-2011, 04:20 AM
  4. FS: dome interior lights outside rear view mirror
    By typ901 in forum For Sale: 911 Parts
    Last Post: 01-23-2011, 10:41 AM
  5. Hella interior dome lights - wich one is correct?
    By vricardo in forum Technical Info
    Last Post: 12-14-2010, 04:52 AM
