Thread: Replacing VIN/Bdoy color plate
    Has anyone out there ever replaced their VIN/Body color plate rivoted into the front of the driver's door jamb??
    Just curious if this DYI job or would need to be done by a body shop? I assume that hardest part is getting the old one off.
    Any ideas would be appreciated?
    Al
    It is actually not really riveted but nailed. It looks like a rivet but is a sort of nail. The best is to flatten the round head carefully with a dremel and then drill it out. You can get the rivets/nails from Stoddard or other suppliers.
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Thanks Michael, I'll give it a try.
  1. '67S Color Code Plate
    By 71Coupe in forum General Info
    Last Post: 08-26-2013, 12:48 PM
  2. replacing shocks
    By r14 in forum Technical Info
    Last Post: 02-01-2011, 09:15 AM
  3. color plate rs #0788
    By fg1227 in forum General Info
    Last Post: 10-23-2009, 09:25 AM
  4. Replacing the Muffler
    By bbulkley in forum Technical Info
    Last Post: 06-21-2007, 03:39 PM
