Thread: SWB S bumper and rocker deco rubber
    I was just poking around the Pelican site. I see that they list wide rocker deco rubber inserts for 65-68 (PEL-TMP-9387); wide S rubber strips for the front (PEL-TMP-9306) and rear (PEL-TMP-9454 bumpers.
    Are the bumper rubber ends shaved and tapered properly or is this a do it yourself deal? Same with the rocker rubber inserts?
    I'd appreciate hearing about anyone's experience with these products.
    Thanks!
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Senior Member egbert's Avatar
    Mar 2007
    Amsterdam
    rubber
    Hi Neil
    PM sent
    rgds eg
    Dec 2006
    Las Cruces, New Mexico
    The ones I received were terrible quality. Ends are shaved but the match where ends are glued stood proud 1/8" 'not blended flush. You can spot them as poor quality 10' away. Also be aware that 68 was shorter due to reflector and will be way short on 67 not a problem if you get the long rears for a 68 you can cut down, one size does not fit all. I believe 67 was the only year the wide LONG S rear deco was offered. I suppose you could fix them up but when I thought about it crap in crap out came to mind. Same thing with the aluminum deco repro's out there, not anodized, stick out like a sore thumb as well as needing tweeking and rubber does not fit well leaving gaps between rubber and deco.
    Early 911S member #166
  1. 1967 911S Rocker deco and rubber, new product from AFS
    By Soterik in forum For Sale: 911 Parts
    Last Post: 09-15-2018, 03:38 PM
  2. FS: NOS rocker deco rubber 1968 - 1973 and deco trim hardware
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 10:34 AM
  3. where to get correct bumper deco strip base rubber? ('67)
    Last Post: 11-01-2013, 11:20 AM
  4. Replies: 7
    Last Post: 10-14-2013, 09:57 AM
  5. FS-early 'S' front bumper deco with rubber
    Last Post: 02-10-2010, 03:00 PM
