Results 1 to 1 of 1
Thread: WTT: 911 Solex parts for parts
    So, I was getting ready to put away my Solex's for my 65' 911 and part of my hardware has gone missing. I'm hoping that in releasing some of my extra parts I can complete my carbs.
    The part that went missing are from the butterfly shaft to the carb pump on all six carbs. I have the aluminum plates for the pumps.
    So here is what I have to trade:
    -Three polished velocity stacks, I have few retaining brackets if you need them
    -One carborator air cleaner base plate, the brether tube has a bit of wobble
    -One small carb bracket
    -One large carb bracket
    -One Carburetor side cross bar, length 9.5 inches or 24cm
    -One banjo bolt, not pictured
    -Three Solex cores, with not hardware other than butterfly shaft, not pictured, all matcing.
    -Pair of manifolds, this is less likely to give up, but if you have the parts I need.
    What I need:
    -24 carb pump oval head slotted screws
    -6 pump lever pivot pins
    -5 pump levers
    -6 pump shafts
    -6 shaft arms with ball pin
    -2 banjo one inlet piece
    -4 banjo two inlet piece
    I post prices if I have to, but I'm trying to just spread this stuff out so we can put these cars back on the road.
    Casey
  1. Replies: 1
    Last Post: 01-09-2014, 12:17 PM
  2. WTB: Solex parts
    By preS in forum For Sale: 911 Parts
    Last Post: 05-15-2011, 05:44 AM
  3. Parts ID help please, Solex?
    By MarkS in forum Technical Info
    Last Post: 10-27-2009, 04:50 PM
  4. FS: Solex PArts Lot
    Last Post: 07-28-2009, 12:36 PM
