Results 1 to 10 of 10
Thread: H1 bulb question
    H1 bulb question
    H1 uses 2 halogen bulbs, there is a 55W version and a 100W
    what correct bulbs should be used?
    is one for high beam(100W)? or just brighter?
    or low beam 55W and 100W high?
    I found both types in both locations (100/100)
    thanks
    Richard aka le Zookeeper
    early reg #1128
    Usually they used 55/55W Lo/Hi, but when people wanted more the replaced with 100W. You should however install relays when going to 100W. Gordon
    thanks!..........
    early reg #1128
    Nov 2003
    Santa Monica CA
    100W bulb
    What is the downside of using a 100W bulb without a relay?
    melted wires. car fire. death
    Early 911S Registry #750
    1970 911E - The Good Stuff
    2001 Toyota Landcruiser
    Jul 2003
    Santa Cruz, CA
    The sockets need to be changed out too if going to 100W bulbs. THe existing sockets were not intended to handle that much current.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Oct 2008
    Burford, ON, Canada
    - what sockets do you buy & where?
    Jul 2003
    Santa Cruz, CA
    Ceramic body.
    Daniel Stern Lighting
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Jul 2003
    Santa Cruz, CA
    Something else I thought of yesterday....
    The original H1 rating was 55W/55W so, the wiring on the light itself from the plug to the bulbs will reflect that (with margin of course).
    Before considering 100W bulbs (almost twice the current) I would determine the wire gauge on the buckets and consider upgrading that wiring if I determined I was close to the limit.
    I'm not to that point yet on my car but, since my thought of using 55W/100W on my H1s this is what I plan to do before implementing any changes.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  1. Turn Signal Bulb Question
    By beh911 in forum Technical Info
    Last Post: 07-29-2014, 11:57 AM
  2. Single Post Bulb Holder Question
    By ret9191 in forum Technical Info
    Last Post: 11-14-2013, 05:28 AM
  3. Bulb for Hella 118
    By kissov356 in forum Technical Info
    Last Post: 02-25-2012, 07:43 PM
  4. H4 Bulb question
    By rvdv in forum Technical Info
    Last Post: 08-24-2003, 05:28 PM
  5. H1 headlamp bulb question
    By Wolf Knierim in forum Technical Info
    Last Post: 06-20-2003, 04:22 PM
