Results 1 to 8 of 8
Thread: rear brake caliper
    1973 911 # 58 Francois Duval's Avatar
    Dec 2003
    Montreal , Canada
    rear brake caliper
    is there any down side of putting the rear calipers Reversed ?
    I am ending up having 2 right side rear calipers for a 1970 911 T
    I know it will fit but the hard line will be on top of the caliper instead of going under.....! Does that matters ?
    help grately appreciated . Thks
    Francois
    Oct 2008
    Burford, ON, Canada
    You will have a bitch of a time bleeding it. I'm not sure if the pistons are flat or notched on that one. That may need attention. If you are in Canada, I might be able to help by replacing the wrong half. I have a bunch of the calipers.
    Dec 2003
    Montreal , Canada
    rear calipers
    Hi Dave, Yes I am in Canada, near Montreal, Quebec.
    If you could help that would be great. I need the rear driver`s side .
    Let me know how we could proceed.
    Francois
    Jan 2007
    North of the GG Bridge
    If they have the hard external line and double bleeders then they are reversible; remove the crossover line and bleeders and change position. As mentioned if the pistons have a 20 degree diagonal then they need to be re-positioned.
    Oct 2008
    Burford, ON, Canada
    Are your calipers rebuilt or well used?
    I have a bunch of cores without spacers, so I would need your caliper, and put a new back half on it. Or, if you want to send both calipers I can do a full refurb on them before returning a matched set. You can either mail them to me or Greyhound. Cost depends on what you need done to them. I'd prefer doing the reassembly myself unless you have the tools and the experience to replace the part yourself.
    Dave
    Dec 2003
    Montreal , Canada
    rear caliper
    Hi Dave, I already ordered a rebuild kit from my local car quest store.
    I can do the rebuild myself , no problem.
    All i need is a good complete left caliper , do you have one for sale or can we trade one ? The two I have needs rebuild anyway.
    Francois
    Francis,
    You have both a PM and an email.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Oct 2008
    Burford, ON, Canada
    For little more than the cost of shipping I can send you half a caliper. For example I have a few of these:
  1. Rear caliper brake line hookup (67)
    Last Post: 10-05-2013, 12:05 AM
  2. FS: Weber & ALU brake caliper
    By typ901 in forum For Sale: 911 Parts
    Last Post: 06-12-2011, 08:08 AM
  3. Brake caliper bolts SWB
    By tlmsf in forum Technical Info
    Last Post: 03-28-2010, 02:05 PM
  4. FS - New Rear M Caliper Brake Pads (Hawk, Porterfield)
    By tom1394racing in forum For Sale: 911 Parts
    Last Post: 02-21-2010, 02:17 AM
  5. '67 S brake caliper rebuild
    By Ed B in forum Technical Info
    Last Post: 02-24-2005, 07:38 PM
