Results 1 to 2 of 2
Thread: SWB front suspension question
    I have quick question...
    In converting a '67 to later struts and A-arms, can I still use the '67 crossmember?
    Todd
    Why would you...
    You can pick up a light newer aluminum crossmember cheap. And then the later struts and a-arms will bolt right up...no fuss. You will save weight and not have to worry about the early heavy steel crossmember and rust
    registry# 1283
  1. Front suspension pan - generic question
    By Greg D. in forum General Info
    Last Post: 11-20-2012, 07:01 AM
  2. Another SWB Front suspension question
    By MTemp in forum Technical Info
    Last Post: 07-25-2011, 08:52 AM
  3. Front Suspension Rust Repair Question
    By FrankT in forum General Info
    Last Post: 02-18-2010, 07:27 PM
  4. Front suspension question
    By tar356 in forum Technical Info
    Last Post: 01-04-2010, 02:38 PM
  5. 1970S - front suspension pan question
    By teveo in forum General Info
    Last Post: 11-10-2008, 02:34 PM
