Thread: SWB rear vented brakes question
    I've done a bunch of reading on this but can't seem to find a clear answer. can I use regular rear ( solid rotor ) calipers on my SWB with rear vented rotors by using the spacer between the caliper halves. I have a set of freshly rebuilt SR calipers. I'd like to rebuild my VR calipers but wish to drive the car meanwhile as it may be a lengthly process. can I separate the VR caliper halves and use the spacers between the SR caliper halves? I'd also have to change over the crossover line, and I know the pistons aren't the same diameter. but will this work? thanks, Don.
    I believe the reason most people do not split the calipers when rebuilding is due to difficulties in finding new O-rings to seal the fluid passages between the caliper halves in the case that the originals are damaged upon removal. Other than that, I think your spacer plan is quite do-able. Eric Shea would lknow better but I seem to recall seeeing some "dogbone" spacers for some special project 914-6 or other, which he is so fond of.
    Best Regards.
    Nov 2008
    Finland
    Quote Originally Posted by Flieger View Post
    (IIRC) SWB rear calipers do not have O-rings as they do not have fluid passages between calipers, there are crossover lines. But unfortunately I can't comment if original question is doable, I'll use S-calipers on mine. (also Alan UK is selling kit with new rear vented discs/calipers)
    - Ville -
    1967 911 Slate Grey/red, fully restored + 66' "r-ish" hotrod project
    Oct 2008
    Burford, ON, Canada
    There is no reason I can see that it will not work. The primary differences between the calipers are the spacers and the piston sizes. The piston size is not a significant factor, and you have the spacers, lines & longer bolts. Verify the caliper is centered over the rotor, and you are good.
  1. Rear SWB vented caliper kit. (all new parts)
    By Alan.uk in forum Technical Info
    Last Post: 10-28-2019, 08:43 AM
  2. 67/68 vented rear brake rotors
    By gled49 in forum General Info
    Last Post: 11-16-2013, 05:22 PM
  3. Replies: 4
    Last Post: 12-10-2012, 10:23 AM
  4. Rear Vented Rotors
    By pacarguy in forum Technical Info
    Last Post: 06-30-2008, 03:12 PM
  5. Rare SWB Rear Vented Brakes @ Trailing Arms, FS
    By archncraft in forum For Sale: 911 Parts
    Last Post: 11-12-2006, 12:46 PM
