Thread: '66 911 Handling
    '66 911 Handling
    I recently purchased a '66 911 with the original 4.5x15 steel wheels. Tires are stock 165-15 size but an unremarkable brand (Nankang). I had heard that the original size wheels/tires made for vague handling compared to modern performance tires, and this seems to be so. In strong winds, it's a bit of a handful. I've had a few 912s with 60 or 65-series tires that tracked with much more confidence. I do like the softer ride that comes with a taller sidewall, though.
    I'm considering a few choices to improve handling while keeping a stock appearance, and I'd appreciate your opinions.
    1) Replace the Nankangs with a decent tire such as Vredestein, keeping the stock 165-15 size.
    2) Go with a 5.5x15 steel wheel with the 185/70-15 Vredestein to keep the same rolling diameter.
    3) Go with the 5.5x15 wheel with a 185/65 or 195/65 tire, of a brand to be determined.
    Your comments, please!
    Apr 2004
    I have the Vredesteins 185/70 (on 6's).
    Nice tire.
    My car was a wanderer, then the suspension was redone and lowered and corner balanced and now she is stable.
    Du must schwein haben
    901/05 #305701
    Bultaco Metralla 62 M8
    1968 BMW R69S
    Early911SReg #606
    I wonder whether the presence, or absence, of the cast iron weights in the front bumper would make a difference.
    Tom F.
    Long Beach, CA
    Jul 2008
    South Florida
    Quote Originally Posted by Tom F. View Post
    Yes to the weights in regards to stock tire size... otherwise rotation is noticeably quicker with somewhat vague steering at the limit; not a good thing. Also helps stabilize ride, making it less choppy over uneven surfaces. Lowered a bit with stock bushes, the 165 Vredesteins on stock 4.5 X 15 wheels make for very entertaining handling, as Porsche's engineers intended.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Apr 2004
    Mine had the weights before the rehab and still do - so it was not the weights that made it handle (noticeably) any better or worse in my case.
    901/05 #305701
    1968 BMW R69S
    Early911SReg #606
  1. SWB better handling
    By 911DP in forum Technical Info
    Last Post: 01-31-2011, 07:27 AM
  2. The cause of my handling problem?
    By Dezzmo in forum Technical Info
    Last Post: 08-24-2008, 05:08 PM
  3. Suspension: comfort versus handling
    By kenikh in forum General Info
    Last Post: 05-30-2008, 03:49 AM
  4. Model years & difference in handling?
    By Val in forum General Info
    Last Post: 12-10-2003, 04:19 PM
  5. Sorting handling on a '67
    By AndyR in forum Technical Info
    Last Post: 08-31-2001, 05:12 AM
