Thread: 245/250 mm Fan Blade
    Outside of pure measurement, are the any markings/numbers on the fan that represents the different fan sizes. I just picked up a new 5R housing and fan blade that are in great shape. I sourced them from different people and never thought about the fan size difference. I put the fan inside of the housing and it seems very snug. It turns, but rubs. That could be because it is not mounted. I hope I did'nt blow this one.!
    RGruppe member 445
    Jan 2003
    UK
    There is very little clearance between a (matched) fan & housing anyway - I would be surprised if there's as much as 5mm difference between the overall diameter of the fan & the internal diameter of the housing - so I don't think a 250mm fan would even fit inside a 245mm fan housing.
    Having said that, I haven't tried it ...
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Hi,
    In case it helps a 250 fan will not fit in a 245 housing without modification.
    Alan
    Pfeeeew. Thanks for the help. I think you are right. I think it is a 245 mm fan.
    RGruppe member 445
    Oct 2008
    Burford, ON, Canada
    Just out of curiousity, where is the measurement taken? Inside of the housing, or outside of the blade.
    My understanding is from the front and from blade end to blade end. Some have said to measure it by halves and doing that from the middle section where the mounting nut goes to the blade end.
    RGruppe member 445
  1. WTB: 11 blade fan
    By denson in forum For Sale: 911 Parts
    Last Post: 08-14-2013, 12:27 PM
  2. WTB: Looking for 911 fan blade
    By Elferhelfer in forum For Sale: 911 Parts
    Last Post: 07-31-2013, 04:52 PM
  3. FS: 11 blade fan
    Last Post: 03-12-2013, 04:01 AM
  4. WTB: 11 Blade Fan
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 12-01-2009, 03:25 AM
  5. WTB fan blade
    Last Post: 11-29-2009, 04:27 PM
