Thread: 2.2L vs 2.4L "E" Visual Distinctions
    Aug 2007
    The Woodlands, TX
    Yes....I know, serial numbers and looking inside are the true ways to determine the nature of an engine, but can "E" gurus on the board post any outward visual distinctions between the 2.2L and 2.4L...e.g metal vs plastic air covers, etc. Decals are always deceiving.
    Thanks!
    -Mike
    EarlyS #1320
    '71 T/RS LWT 3.2L
    Jan 2003
    UK
    If the engines retain their original mfi, the 2.2 will have magnesium stacks & the 2.4 will have plastic stacks.
    If air cleaners are original the 2.4 will have a 'warm-up' valve as part of the 'snorkle' (circled in yellow below) but this is often removed:
    Andy
    Early 911S Reg #753
    R Gruppe #105
    In addition to Andy's answer, the distributor clamping methods are different between 2.2 and 2.4. The 2.2 uses a pinch type clamp, the 2.4 has a slotted cast boss on the distributor that sits over a stud. Also I don't think the 2.2's had vacuum retard units on the distributor.
  1. FS: Special Extended Hub 380mm "RS" "RSR" Thick Grip Steering Wheel
    By Allen Henderson in forum For Sale: 911 Parts
    Last Post: 06-06-2014, 12:47 PM
  2. FS: Special Extended Hub 380mm Thick grip "RS" "RSR" steering wheel
    Last Post: 10-30-2013, 01:47 PM
  3. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 03-03-2012, 08:51 AM
  4. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 02-18-2012, 09:24 PM
  5. FS "RS" "RSR" Special Extended Hub Thick Grip 380mm Steering Wheel
    Last Post: 01-24-2012, 01:59 PM
